by wayne » Tue Feb 23, 2010 2:20 pm
hi guys
i was riding home from work the other night when a stone smashed my headlight, just wondered if anyone knows of a replacement headlight that will fit the baghira as grahams want £63.
i was going to get an acerbis DHH OR CYCLOPS but wasnt sure about how easy it was to fit or if i could keep the original clocks.
any help would be greatfully recieved
thanks
Wayne
wayne
by hutchy » Wed Feb 24, 2010 3:59 pm
Hi Wayne,
I had the same problem but found that a KTM headlight was a perfect match, the only problem is that i can't remember which model it came off. I've had a look on jerseybikers KTM site and I think they are about £42 but you may be lucky and get one off Ebay as i did.
This headlight seams fairly common on a lot of their bikes so you could try them to start with. if you stuggle I might be able to get a part number off mine next week.
Good luck..........Hutchy
hutchy
by mr-brightside » Thu Feb 25, 2010 3:53 pm
most of the enduro type lights for around £40 shoul come with all the fixings and should fit easy enough, only trouble with them is most will have a plastic lense so you cant use a halogen bulb ive got one on mine (see pics in galery) and the light is not very bright
mr-brightside
