newbie questions
newbie questions
Postby tall guy » Sun Dec 20, 2009 6:56 am
Hi all was on here a few years ago when I was looking at a baghira but ended up with a ktm duke 2 great bike but now have a tdm 850 , am really fancying something diffrent so want a baghirah again want to make a kinda special ! I've read a lot of the threads about engine tuning and yes I plan to do the fcr carb and exhaust and stuff nothing to major like overboring or owt but was wanting to lighten it a bit so was wondering any of u remove stuff like the headlight ,mirrors and can u remove the tubing at the front that the headlight is fixed to ? And maybe lighter wheels not sure yet ! I'm a Sunday rider don't get out much so 1500 2000mls a year would b a lot for me and neva at night hence the want to get rid of the headlight as its extra weight ? Any ideas welcom thanks in advance :) sorry bout the punctuation I'm on ma phone !
tall guy
Re: newbie questions
Postby Anders » Sun Dec 20, 2009 8:41 am
Sure you can remove lots of stuff and still have bike that runs, but will it still be street legal without lights etc?
Other than that, go for it, remove anything you dont need or replace with something less heavy. Allmost anything is possible and only your wallet, fabrication skills or imagination will be the limiting factor.
In my garage:
Honda VTR 1000F -00
Orion-29 125cc, Midsize
49cc Bike engine kit toy
Yamaha SRX-6 -86
MuZ Skorpion 660 -95
Polaris 6x6 Big Boss
Nordic SRX/MuZ/SZR forum
Anders
Postby DAVID THOMPSON » Sun Dec 20, 2009 11:06 am
get a big box and put all the take offs in it
later when you sell it it will bring more as the fellow looking to buy may want a stock
bike
i hate modified bikes
only thing i change is the handle bars so i can stand to ride them
example rt125 uses same air filter as 660 motors
why change it i tried that before i knew both were the same
and all it did was made the gas mileage worse
Postby tall guy » Sun Dec 20, 2009 12:26 pm
Thanks lads ! I'm a service eng so I can hold a spanner :) my mate is in the bike business and tells me that I can get a daytime mot for it if it doesn't have lights and stuff u don't even need brake lights I'm told that if its on your bike it has to work but if u remove it that's fine but u do need a reflector on the rear :) gona look into all this after xmas when I can get rid of my tdm ! Always liked the baggy as it just a bit diffrent loved my ktm duke but saw loads of ktms out and about even if it was a special ed !
tall guy
Postby mr-brightside » Sun Dec 20, 2009 3:58 pm
this may be of some help to you.
http://www.ukmot.com/bike_index.asp
ive got none of that metal work on my baghira light as its been replaced with an enduro type light. i was told a day time mot is exactly the same bit of paper as a normal mot bit of paper?
mr-brightside
Postby DAVID THOMPSON » Sun Dec 20, 2009 9:48 pm
i would go for a BIG brake lamp at least ...
here in my state West Virginia got to have it all including turn signals after 1972
they made us do the headlamp in 1966 even if you go home before dark
wish they would do some thing about the bicycles here.. i have almost hit 3 of them in the last year at night
with no lights or reflectors
Postby handsomejackuk » Tue Dec 22, 2009 7:23 pm
this may give you an idea on what you can do, mine is currently 140kgs take a look at my pics on flickr i have totally removed the front framework, the rear mudguard has been removed, speedo and speedo cable has been removed, front fork delugged, XTZ 660 supermoto mudguard, led rear light,
gallery/menu.php?gallery=members&album_id=4&sid=4f075ae010c6a2c1c86aeb58073459ac#
http://www.flickr.com/photos/25719146@N ... 574774475/
the list goes on.....
Awesome bit of kit.....
Feel free to ask questions....
Al...
Postby tall guy » Sat Dec 26, 2009 10:03 am
Thanks mate thats more like it :D im guessing to remove the stuff its just simple bolt off stuff ? thought the exhaust and headlight gubbins would weigh the most? 140kgs thats lighter than my duke 2 was im sure it was about 145 ish ! it had 50hp and was pretty good but im hoping that i can get more outa the baggy with a fcr and stuff ? u done much to the engine ?
tall guy
Postby handsomejackuk » Mon Dec 28, 2009 2:00 pm
yeah the headlight was a bit of a pain to relocate, as i wanted to get it to sit as close to the bars as possible, Eventually, what i had to do was bend the prongs on the Halogen bulb flat, and put seperate crimps on to the bulb terminals, I have comlpetely removed all of the dash board, and associated assewmbly, as i did not find the MZ Speedo very accurate, I have made my own dashboard Neutral light, main beam, indicator idiot lights using l.e.d.s and resistors, I have used a Cycle speedo setup, and this has proved to be very reliable, and accurate,, according to my sat nav they are the same...
Exhaust is a BSM vampire with removable DB killer very loud with Db killer out, also have a Future end can, but dont tend to use that... as far as engine is concerned, only thing i have done is alter the Gearing cant remember what it is now, but top speed is about 90m.p.h, with fearce acceleration for 40-70.... think i went 4 teeth bigger on rear and one tooth larger on front.....
Al...
Postby elcaptain69 » Mon Jan 04, 2010 3:37 pm
Ditto to all the above. i never liked the tube around the headlight, cropped it all back. (see pics). Used bullet l.e.d's which finish it off and look great head-on (i think)
elcaptain69
