Quick-turn throttle
Quick-turn throttle
Postby Roadstergal » Thu Oct 08, 2009 11:17 pm
Yes, I'm just going to ask away until I get this thing sorted. :)
Is it possible to make the throttle a little quicker? It's got quite a looong turn - about a half-turn or so? 1/4 or 1/8 would be nice.
Roadstergal
Re: Quick-turn throttle
Postby Jamie » Fri Oct 09, 2009 7:57 am
Have you looked at a motorcross after market one, gunner gasser or similar.
Jamie
Jamie
Postby Roadstergal » Sat Oct 10, 2009 5:59 pm
Yep, I just wanted to check and see if anyone had tried another bike's stocker as a cheaper option.
M'boy had an R6 throttle tube ('03, I think) lying around to put on one of his own bikes, so I nicked it. It works with no modification at all (just loosening up the thottle cable a bit). It's about 1/6 turn now. I highly recommend it!
Roadstergal
Postby truckstop » Mon Oct 12, 2009 11:26 pm
Funny how the Yammy throttles work on other bikes, R1 tube turns a 600RR into a 1/4 turn. Thanks for posting about this, R6 throttle tubes can be found super cheap, might have to try it on the Baggy.
truckstop
