Baggi SM problem
Baggi SM problem
Postby keithcross » Thu Dec 09, 2004 3:57 pm
Well I suppose something had to give in the end. It seems serious this time, a noise started in the motor about a week ago and gradually got worse, by Tuesday this week I could hear it even with my crash helmet on and wearing ear plugs. The noise is a rumbling sound that is dependant on engine not road speed so is within the engine/generator/primary drive and gets louder and quiter at tick over. It can be heard on teh overun, but not on acceleration but this could be down to exhuast and induction noise.
I stripped out the engine clutch case and removed the clutch and pimary gears, no signs of problems there. I then took of the alternator cover, agian no signs of teh problem there.
I am going to remove the engine unit this weekend and put in my spare (brought for £180 from EBay) and will then look deeper into the engine, as any problem further in the engine will require its removal anyway. It may be the cam chain, but I doubt it with only 26000 miles (40000+kms) and will post what I find.
I dont suppose anyone has any ideas on what it might be?
Postby Dezmo » Thu Dec 09, 2004 5:15 pm
just a thought, but have you checked the cam chain tensioner?
Hella Yella, coming ta getcha!
Dezmo
Postby phlat65 » Thu Dec 09, 2004 9:46 pm
my XT600 had a pretty good rod knock, it would go away under load, and if you dragged the clutch at a stop. about the same mileage too. but I think I only changed the oil 3 times during those 25,000 miles :(
2001 MZ Black Panther
phlat65
Postby keithcross » Sun Jan 30, 2005 6:21 pm
Well I finally got around to taking the head and barrel off of the MZ Baggi engine and found teh following.
1.
Slight wear on teh big end, this suprised me because when I loaded up
the engine on teh rear brake until the motor stalled there was no knock.
2.
Therw is a lot of wear on the piston skirt ant the front and rear. It looks like I may have had a partial siezure.
So now its a search for parts to see if its worth rebuilding the engine. I will keep it anyway, just in case I get the not unkown gearbox problem. I Might end up looing for another spare engine unit to keep just in case. It might even be worth buying a cheap MZ with a 660 engine and selling the rest on.
Postby keithcross » Wed Feb 02, 2005 8:21 am
I got the following rely when making enquiries to MZ Germany. Seems a bit of a low kms for this kind of work.
Dear Keith,
Following is the answer from our technical department:
Yamaha recommends to install a new piston after 40000 km. It is not necessary to grind (hope that's the correct word) the cylinder at the same time.
Maybe you should try this.
In order to get to know the price for a new engine or to get other parts, please contact BSA Company Ltd. in Southampton under phone 02380 366 404 or e-mail: phil@bsa-regal.co.uk. They handle the complete MZ spare parts business.
Kind regards
Mandy Schaarschmidt
International Sales Dept.
Postby oldboyonrgv » Wed Feb 02, 2005 9:57 am
while youv'e got it apart put a J.E piston in have a look here
http://www.jepistons.com/pdf/2002-motox9.pdf
they ahve a selection for the 660 (and 680 720 !)
If you order direct from J.E its cheaper than buying from Martin or TTS
oldboyonrgv
Postby oldboyonrgv » Wed Feb 02, 2005 9:59 am
oldboyonrgv
Postby hulagun » Wed Feb 02, 2005 3:33 pm
The guy who modified my Y-pipe built a really cool XR650L Supermotard and installed a 12:1 J&E piston in it. He says it really woke up the motor and ran fine on pump gas. He also installed Keihin smoothbores but that's a diffferent story.
Ivan
1978 Ducati 900SS cafe racer
1969 Triumph Bonneville 650
1966 Honda CB160 F160 racer
hulagun
Postby keithcross » Wed Feb 02, 2005 6:13 pm
Thanks for the help guys. I am also looking at standard +.5mm piston for a rebore. 1 of my contacts in the states reckons he can supply one complete with rings for $70 comlete with rings or £36.50 gbp. Plus P&P of course.
Postby keithcross » Sat Feb 05, 2005 4:01 am
Well after looking further at the engine, I dont think it is a viable propostion to rebuild it. Just took a look at the inside of the oil pump. The working parts inside are scored to hell. This would explain the damage to the piston and may indicate wear to the rest of the engine gearbox internals.
Good job I had that spare engine. I have also been in contact with a guy who builds these engine up for racing. He is getting a bike in that is a good runner and all he really wants is the crankcases after a customer blew up his engine and is prepared to do a deal. As he rebores the engines to fit a big bore kit the barrel and head will be of use to him as well as other componants.
I am keen to have a spare engine as I use the bike a lot and if its off of teh road I have to use a Goldwing to commute to work and on the roads I use that not a good idea.
Postby Whysub » Sat Feb 05, 2005 7:09 am
keithcross wrote:................ I have to use a Goldwing to commute to work and on the roads I use that not a good idea..............
In that case, can't you ride it cross country :-D :-D
Moto Guzzi V1200 Sport
Honda CBR600 F-V
Suzuki SV650S -Y
Yamaha Vity
Suzuki Hokuto
Whysub
Postby keithcross » Sat Feb 05, 2005 10:55 am
Whysub
You obviously havnt seen my GoldWing 1100 Enduro bike :D
Still not much good off road though
Postby keithcross » Sat Feb 05, 2005 7:40 pm
It never rains but it pours.
On Thursday, I was looking at the bike and noticed the state of the rear sprocket (Renthal alloy). I new it was getting worn, but all of a sudden some of the tops of the teeth were missing. Called my local shop and they had a chain and the sprockets for a Yamaha XTZ660 in stock, so after work I went and got them.
Got home and set about fitting them and all went well, except I noticed some play in the rear suspension. I traced the play to the bearing for the bottom of the rear shock.
Quick call to BSA Regal the next morning confirmed they had the bearing in stock. The guy sais I wasnt going to like the price though £51 for the bearing and the spacers and seals I thought I might need. :shock:
Also ordered a set of rear brake pads as they were getting a bit low.
The bearing arrived in teh post this morning (thank BSA Regal, less than 24 hours again) and have now fitted it.
When I ordered the bearing the soares guy first offered me the complete suspension arm - but at £150 I declined. He certainly knows his stufs, it would have been a lot easier to have payed this out. A lot less hassle and looing at teh rest of the bearings, while they are OK they will need replacing soon.
Lessons learnt,
1.When a spares man offers parts you think you may not need ask him why he made the offer.
2.It is worth taking the linkage apart every now and again to lubricate the bearings, unfortunatly not all of the bearings have grease nipple on them. I do a fair bit of off raod riding on teh bike and teh bearings without grease nipples were bone dry. All of the grease had been washed away.
Looking at teh bike I might as well replce the rear tyre tomorrow as its done to less than 2mm.
Although the bike has given me a few troubles recently, I am still keeping it. Might be tempted to part ex it next year for another Bagi SM though.
Postby Whysub » Sun Feb 06, 2005 6:46 am
keithcross wrote:Whysub
Oh, I have seen it :!: :!: :!:
You are a very brave man :-D :-D
Honda CBR600 F-V
Suzuki SV650S -Y
Yamaha Vity
Suzuki Hokuto
Whysub
Postby keithcross » Sun Feb 06, 2005 10:45 am
Whysub
Tried to green lane on it once, it had a suprising amount of grip (could have been down to the weight giving lots of traction) and all went well untill I came to some deep ruts, dam cylinders jamed on the side of the ruts :shock:
Good job I had a few mates with me to help turn it around :D
Users browsing this forum: No registered users and 237 guests
