radial master cylinder brake /clutch
Postby handsomejackuk » Mon Jun 22, 2009 4:39 am
I am wanting to upgrade my brake / clutch setup. ideally, would like to go to hydraulic clutch. anyone done this or have any advice on this. ?
brakes purely for easier adjustment at lever end, and cosmetic, and clutch for easier clutch action. was looking to get a radial master cylinder off ebay first to try the brake side, then go along the hydraulic clutch route later on. possibly a uprated caliper setup as well.
any ideas on this ?
Alun
Re: radial master cylinder brake /clutch
Postby handsomejackuk » Mon Jun 22, 2009 5:03 am
Postby RiverDrive » Mon Jun 22, 2009 6:36 am
If the price sounds too good to be true...
Get something you can trust your life with.
My I humbly suggest you get the brembo caliper first, much more bang for the buck.
01 Sport Cup Gone Sport
RiverDrive
Postby Bill Jurgenson » Mon Jun 22, 2009 7:14 am
I was just going to say the same thing.
and get a first class steel braided (or Kevlar or CF) line.
A radial pump is a waste of money, in particular as there aren't any in a reasonable price small enuf for a single rotor. The one in the link looks to me to be a (chinese?) copy of an early Brembo. I would not touch it if I were you. In my racer, I did use a billet radial pump and billet caliper, but racing is a different catagory. I seriously doubt that you are looking to spend 800 or 900$ (for both items). Anything for much less is not up to much and potentially dangerous.
Look for a PS 13 and an adjustable lever to go with it. Both can be had new from Brembo or used, for instance from a Mito or a TZR or...
Then there are several aftermarket levers to fit the Brembo pump. for instance this one from ABM:
http://www.ab-m.de/en/products/synto
and there is wire clutch lever to go with it.
Magura does offer an hydraulic conversion kit for wire-pull clutches
http://www.btosports.com/p/MGHC
You are beter off getting a really good clutch lever assembly, tho.
Accossato or Domino for instance. Go here
http://www.redracingparts.com/en/english.htm
and click on the left on wire clutch controls. I use the one at the bottom.
or this from Accossato:
http://www.agmoto.it/dettagli.asp?sid=80534349420090622140249&idp=260&categoria=
the bee's knees but plenty expensive, too.
there are several more brands used in racing, all very expension.
