LARGER BRAKE PEDAL / GOT BIG FEET.
Postby jim grace » Tue Nov 09, 2004 6:00 am
:P Hello out there, does anyone have any information on a larger pedal for the rear brake lever also ? what alternative rear brake disc/roter are available, finaly what tyres are available that will endure high milage CHEERS JIM.
jim grace
Postby Nobog » Tue Nov 09, 2004 8:09 am
Jim, its not likely to find a different brake pedal on the aftermarket, you can hardly find a luggage rack after all. Sounds like its time for the welder or a good machine shop for something like that, good luck, JK
Nobog
Postby hulagun » Tue Nov 09, 2004 3:47 pm
You didnt specify what bike you have but on the Baghira models the brake pedal has a removable pedal end. You could maybe put a spacer in and a longer bolt to make it easier to use. If the lever length is too short tho it is time to get out the welder.
2001 MZ Black Panther
1978 Ducati 900SS cafe racer
1969 Triumph Bonneville 650
1966 Honda CB160 F160 racer
hulagun
