speedo cable gone
speedo cable gone
Postby handsomejackuk » Tue May 12, 2009 2:34 pm
Just binned my speedo cable as no longer needed / used, only probem is am left with the two holes on the fork legs that serve no purpose, and a speedo drive on the front axle, that serves no purpose either.
Does anyone know if there is a commercially available spacer i can use on the front wheel. Instead of the speedo drive ?
Also ideas on what to do with the holes on the fork leg. ?
Was thinking of making a bracket to span the both forks to attach my lower mudguard,
or Completely file off the bracket and smooth, and repaint / Polish the both fork legs.
I did notice that another baghira had their forks polished, and it did look nice...
Any ideas ?
May just go for a repaint this year, and look into getting the forks polished in the winter.
Would i have to strip the forks cmpletely down, to get them polished ??
Re: speedo cable gone
Postby DAVID THOMPSON » Tue May 12, 2009 8:42 pm
do not file off someone after you may want to make it like new again
and you just screwed up the fork
i just love bmw /2 frames with the sidecar brackets missing
grinding them off bent up frames to weld back on good frames has become one of my arts
