Baghira Brake Pedal
Baghira Brake Pedal
Postby brucem » Wed Apr 01, 2009 8:35 am
Anyone else find the Baggi brake pedal too small. I've lost count of the number of times I've missed it, and ended up panic braking :(
Any solutions out there? I notice the actual serrated part of the pedal unbolts. Any bigger or better replacements?
brucem
Re: Baghira Brake Pedal
Postby rodge70 » Wed Apr 01, 2009 4:18 pm
hi and welcome to the site,i had the same thoughts once, but never got round to doing anything :roll:
the fact the serrated bit comes off makes the job easier than finding a complete pedal i suppose.if you manage something then a pic may be handy for others,good luck
rodge70
Postby OLDMTNCARVER » Wed Apr 01, 2009 7:14 pm
Interesting...
Mine got replaced with a bolt and a rubber sleeve that looks the same as the shift lever.
Other than that it is a quarter inch wider than the shift levers rubber sleeve.
The total width being one and one half inches wide.
OMC
OLDMTNCARVER
Postby handsomejackuk » Tue Apr 07, 2009 5:33 pm
Dont do the brake thing, just peg it down a couple of gears usually scrubs off a bit of speed...... :smt005
Jak
Postby amahoser » Mon Apr 20, 2009 3:07 am
Too small?? The serrated bit that you press down on broke off my bike some time ago. Never even noticed until I was cleaning the bike. My foot just happens to find the lever just fine. One of these days i'll replace it but it isn't high on the priorities since I never even noticed it was missing!
Jose Soriano
2003 MZ Baghira
2008 Aprilia Shiver
2008 Harley Nightster
2000 Kawasaki Concours
2002 Honda XR400R
2008 Genuine Rattler 110
1974 Vespa Rally 200
1963 Vespa GL 150
amahoser
Postby sethboat » Fri May 15, 2009 5:44 am
The previous owner of my Baghira must have done something drastic because when I received the bike the little bolt on piece was "smeared" severely making it quite difficult to even get at the nut holding it on. I've hammered out the part and upgraded the bolt and nut but I am still working on an aluminum replacement. I'm considering something machined to brace itself along the shaft with a nice beefy fastener holding it. I'm toying with the idea of a flat aluminum surface with a several small threaded studs for traction. My other idea is a knurled cylinder. If I come up with something I'll post
sethboat
Postby handsomejackuk » Fri May 15, 2009 5:49 am
still think yuo should just peg it down a couple of cogs and save your brake pads.!!!! :-D
No need for rear brake anyway....
JAk
Users browsing this forum: Bing [Bot] and 34 guests
