Trail Tech Vapor: Generic or Raptor 660 Specific?
Postby AtomicSpew » Thu Mar 26, 2009 2:15 am
Anybody install the TrailTech on their Baggy, and if so, which model do we use?
03 Baghira
03 CRF150F (w/BBR 175 hop-up)
AtomicSpew
Re: Trail Tech Vapor: Generic or Raptor 660 Specific?
Postby rodge70 » Fri Mar 27, 2009 4:07 pm
yep fitted the vapor to mine,works a treat,only problem was the rev wiring,forget the wrapping the wire around ht lead,erratic readings,get the raptor resistor wire from trailtech and wire straight to coil instead,standard baggy loom and bulb holders fit straight in, just need an extra bulb for the temp warning though the unit can be programed to warn you before it gets mega hot.
think there are pics on post your ride board,page 2 i think and shows the extra led for temp.
doddle to fit as well :D
rodge70
Postby elcaptain69 » Sun Mar 29, 2009 10:10 am
Yep... no problems here. made my own dash.. love it coz its different :-D http://www.bikepics.com/members/elcaptain69/02baghira/
elcaptain69
Postby sethboat » Sun Apr 05, 2009 9:09 pm
So, when ordering, do you just order as if for the Raptor 660?
sethboat
Postby RiverDrive » Mon Apr 06, 2009 5:20 am
I just ordered a trail tech on Fri. I called Trail Teach they where very help full. I was given a part no. to order, I think it was the universal. The biggest concern seemed to be the proper heat sensor. I suggest calling Trail Tech, if you haven't already. Oh ya, my bike is a Skorpion.
01 Sport Cup Gone Sport
RiverDrive
Postby basser23 » Fri Apr 10, 2009 6:18 am
I'm interested in your install on the Skorpion,,,,keep me posted please
Chip
Postby basser23 » Fri Apr 10, 2009 6:36 am
Chip
Postby amahoser » Tue Apr 14, 2009 12:16 am
I don't think the Raptor Specific kit would work because ATV's use a different speed sensor mounting arrangment than the Motorcycle kits. I gambled and got a kit for a Honda CRF and it worked out. The water temp sensor worked just fine. The only problem I had is the RPM sensor did NOT come with with the resistor. I couldn't get the tach to be stable. I called Trail Tech and they sent me a RPM sensor with the resistor free of charge.
By the way, a couple of notes.
Speed Sensor: The magnet fit nicely in the brake disc on my original MZ disc (Street Moto 17" wheel). When I replaced the disc with a Yamaha R6 stock disc, the holes were too small to hold the magnet. I purchased some small neodynium magnets on e-bay the proper size for the hole and it worked fine.
Odometer: The Vapor *technically* does not allow you to adust the odometer. It will come set to zero. This, I believe is a legal requirement to for road legal vehicles. BUT, there is a factory code you can enter to allow you to change the odometer. I used this code to set my odometer to what my original MZ odometer read. So my Vapor odo reads actual mileage and not milage after I changed the speedo. There are websites online that explain how to do this. Do a search on google but if you can't find it, let me know and i'll hunt for it again.
Jose Soriano
2003 MZ Baghira
2008 Aprilia Shiver
2008 Harley Nightster
2000 Kawasaki Concours
2002 Honda XR400R
2008 Genuine Rattler 110
1974 Vespa Rally 200
1963 Vespa GL 150
amahoser
Postby BRAAAP ! » Thu Jul 23, 2009 3:16 pm
Hi, I've just bought the vapor (setting up at the mo and probably have loads more questions :wink: ), could you tell me the process for setting the odometer to the existing mileage ? had a google but can't find anything yet.. . .
Ed.
two wheels good, four wheels bad. . . .
BRAAAP !
Postby RiverDrive » Thu Jul 23, 2009 5:39 pm
Drop an email to trail tech
They will send you a PDF with instructions
Or you can email me off list and I can send it to you
mikedemonte@yahoo.com
RiverDrive
Postby BRAAAP ! » Fri Jul 24, 2009 3:40 am
I've sent you an email. .
thanks very much.
Ed.
BRAAAP !
