HI,
I am the "geezer" named Bill, tho I didn't know tha being 65 qualified one for Geezerdom. when I was kid you had to be a ot older.
Paul van der Wouwer over at the Belgian/Dutch MonoForum posted a sort dity on how to make a new K&Nfor the Skorpion from a Standard K&N car filter.
http://forum.monoconnection.nl/viewtopic.php?t=908&highlight=luchtfilterLike here, you need to be registered to actually do anything there. It is worth it tho, since it is certianly the best of the various fora covering our topic but also the all other Yamaha and Honda singles. If you ask in English, you get an answer in English, tho that is true of all of both German fora as well, both of which also require registration:
Skorpion ForumSZR ForumSeveral of the SZR owners, me too, also have a Skorpion and it is the same engine in a similar bike.
You need a K&N filter for a HONDA civic crx, 85'-87' nr;33-2021.
http://www.knfilters.com/search/product.aspx?Prod=33-2021
- Honda filter
- 2301 220.jpg (160.91 KiB) Viewed 3428 times
you will get two inserts from this.
- clean out original MZ frame
- 2301 222.jpg (95.26 KiB) Viewed 3427 times
Trim a piece of the Honda filter to fit and "glue" it into to the cleaned frame with a good petrol resistance silicon adhesive.
- finished
- 2301 221.jpg (93.24 KiB) Viewed 3429 times
Most of the removavble parts of the Skorpion are italian in original and can be found on any on a number of Yamahas as well as Ducatis or the Cagiva Mito.
The boot over the rear brake switch is a standard dime a dozen item, not a priority part. Ask just about any bike dealer, tho a Yamaha dealer is best.
The switch is used on hundreds of bikes and still more cars. I has the standard M10x1mm thread. The Grimeca brake pumps, especially the rear one, are finky. Don't bother with it when it gets troublesome which it will. Just replace it with a standard Brembo 11mm rear pump found on lot an lots of bikes. Ducatis for instance. Brake pads are the same as any Ducati monster or 750/900SS. Lots of others as well. EBC is the sole source for a new front rotor.
Unlike the substandard calipers and pumps, the steel braided pipes are top quality, you will never have to change those, ever.
Get your rubber hoses and tubes from an industrial jobber. Don't bother with bike suppliers, altho Gericke and presumably Louis do have servicable 6mm and 8mm black rubber petrol hose which will also do as a lead to the brake pump from the reservoir. I have a piece of best quality 1" garden hose in my cooling system. Red at that and everyone thinks it is sexy racing silicon hose.
The original Lenhart & Wagner stainless exhaust is heavy 'cause it is virtually indestructable. Technically, it it top quality as well. there is no reason to change it (except weight). None of the vialble alternatives are as good and a few actually deliver considerably less umph. Loud is not necessarily better in this case until you get into real racing systems, not just bolt-on look alikes. If you want to sacrifice a HP or two, tho there aren't that many to give up, you can go for something like the BSM which is specifically supplied for the Skorpion. Their street-legal can actually does loose out compared to the Lenhart & Wagner, but it is lighter and loud.
gona change them all to ss washes and lock nuts!!!!
And you figured that out all by yourself. I personally use screws like this:
http://www.qualityproducts.de/standard_schrauben/cat_1052.pdfAluminum tho in my case usually black, Mine are from
Poggipolini and can be had in various anodised colors.
For them Aluminum selflocking nuts:
http://www.qualityproducts.de/standard_schrauben/cat_2042.pdfwith 18mm nylon wahsers:
http://www.qualityproducts.de/standard_schrauben/cat_390.pdf I am sure there is an English jobber for these items, but if you want them and cannot find one, I am sure Thomas Ratsch, the German importer, will gladly supply you or you can ask me to send the ones you want. Not much postage involved: aluminum.
order@qualityproducts.deDiligently read thru the archives here as just about any topic imaginable has already been covered.
Check out the MZOG (MZ owners group) over at Yahoo Groups, too.
http://autos.groups.yahoo.com/group/MZOG/ Bill
TuningBlogbill@william-jurgenson.com
