Rear disc
Rear disc
Postby funmonkee » Sun Feb 01, 2009 2:54 pm
ANyone know of a rear disc that will fit the baghira black panther. I've checked the forum and it's suggested the R1 '02 front disc will work as a replacement for the front. But I#d like to find a replacement for the rear too :D
funmonkee
Re: Rear disc
Postby handsomejackuk » Sun Feb 01, 2009 7:47 pm
Funmonkee,
when yah finds out, let me know as i would like to stick a nice tricker galfer / wavey disk on mine...
I need a favour off you after all the advice i given to you
hahah
:shock:
Al...
Re: Rear disc
Postby funmonkee » Thu Feb 05, 2009 2:28 pm
okay dude. I think a Gilera DNA rear disc is close... I'll try to get hold of one at the weekend and try it out :D
funmonkee
Re: Rear disc
Postby funmonkee » Sat Feb 07, 2009 5:57 pm
hello dudes, I've been researching this... and I think ...
OD outside diameter
ID inside diameter
BHC bolt hole configuration
BH bolt holes
OD Ø mm ID Ø mm BHC Ø mm No of BH BH Ø TH min. TH Offset
245 115 133 6 8.5 5 4.5 0
the following bikes rear disc will fit the baggi.... NEED to confirm the diameter and distance between the holes... DOES ANYONHE HAVE ACCESS TO THESE DISCS?????....
VOXAN - Café Racer 996cc 1997-2001
VOXAN - Black Magic 1000 2004-2005
VOXAN - Café Racer 1000 2002-2005
VOXAN - Café Racer 1000 2006
VOXAN - Roadster 1000 2002-2005
VOXAN - Roadster 1000 2006
VOXAN - Street Scrambler 1000 2003-2004
VOXAN - VB1-Evo 1000 2003-2004
YAMAHA - FZ 400 1996-1997
YAMAHA - FZ 400 N 1985-1987
YAMAHA - FZ 400 R 1987-
YAMAHA - SRX 400 1985-1989
YAMAHA - SRX 400 1990-1998
YAMAHA - XJ 400 Diversion 1991-
YAMAHA - XJ 400 S Seca II 1993-
YAMAHA - XJR 400 1993-1996
YAMAHA - XJR 400 R 1995-2000
YAMAHA - XJR 400 R 2001-2005
YAMAHA - XJR 400 RII 1996
YAMAHA - XJR 400 S 1993-1996
YAMAHA - FZ 600 1986-1988
YAMAHA - FZR 600 1989
YAMAHA - FZR 600 1990-1991
YAMAHA - FZR 600 R 1992-1995
YAMAHA - FZS 600 Fazer 1998-2003
YAMAHA - FZS 600 S Fazer 2001-2003
YAMAHA - SRX 600 1985
YAMAHA - SRX 600 1986-1987
YAMAHA - SRX 600 1988-1989
YAMAHA - SRX 600 1990-1995
YAMAHA - XJ 600 Diversion S 1991-1997
YAMAHA - XJ 600 Diversion S 1998-2003
YAMAHA - XJ 600 N 1991-1997
YAMAHA - XJ 600 N 1998-2003
YAMAHA - XJ 600 S Seca II 1992-1998
YAMAHA - YX 600 Radian 1986-1990
YAMAHA - YZF 600 R 1994-1995
YAMAHA - YZF 600 R 1996-1997
YAMAHA - YZF 600 R Thundercat 1998-2000
YAMAHA - YZF 600 R 2001-2005
YAMAHA - YZF 600 R 2006-2007
YAMAHA - TDM 850 1991-1995
YAMAHA - TDM 850 1996-2001
YAMAHA - TRX 850 1996-2000
YAMAHA - TRX 850 Import/ Italy 1995-2000
YAMAHA - TDM 900 2002-2008
YAMAHA - TDM 900 A ABS 2005-2008
YAMAHA - YZF-R7 750cc OWO2 Race Version 1999-2001
YAMAHA - YZF-R7 OWO2 Road Version 1999-2001
YAMAHA - YZF-R1 1000 1999-2001
funmonkee
Re: Rear disc
Postby funmonkee » Sun Feb 08, 2009 4:58 am
If you check out this website... the thunderace 98 rear disc looks good
http://www.braking-shop.co.uk/product_i ... s_id/25746
funmonkee
