winter jobs
winter jobs
Postby handsomejackuk » Mon Oct 20, 2008 5:21 pm
Phase three of my baghira mods.........
Does it ever end ?
Removal of stock speedo and trail tech vapor with dash to be fitted.
Headlight to be moved two to three inches closer to the handlebars.
This may require removal of the ignition switch and relocation to another place, cutting of my aftermarket fork brackets,and repositioning of mini indicators.
Front brake hose to be routed better, at the moment it is fowling my sat nav.
Sourcing a smaller more compact not so deep front headlight to fit into the original headlight fairing (as i like this fairing).
Installation of 5v usb power source for on bike charging of my sat nav.
front rad guards to be exchanged for some clear white ones as the black ones look Crap.
Horn to be painted.
Supermoto mudguard to be fitted shorter (Not to sure about this yet) Opinions please ?
Cut down front side pods by radiator (another not to sure) May buy some black ones and cut thos down. Opinions on cutting down the sides ?
rerouting of rubber hoses by starter motor, the ones that are coming from the crankcase. (What do these do ) ? so as to get beter view of starter motor. (polished).
installation of nice looking fuel filter (chrome type), and stainless steel petrol hoses (overbraid). from tank.
All visible rubber hoses to be overbraided with stainless steel overbraid (obvious really). and hose finishers..
Polishing starter motor casing. (a must) all mounting bolts to be replaced with stainless steel.
new / sourced / made rear mudflap thingy attached to the air box. (Standard is now painted black) but need something a bit tricker. Or I completely remove it, and cover the airbox with stainless steel, or get my mate to knock up a better looking aluminium / stainless steel airbox. ( sounds like a lot of work, but i hate that airbox...........) Any sugestions ?
Smaller front sprocket 1tooth less any views on this..........?
Rear undertray to be fabricated to keep the crap off rear end, polished stainless steel (of course)
Thats all i can think of at the moment.
Jak
