Vapor Settings?
Vapor Settings?
Postby amahoser » Fri Sep 19, 2008 9:56 am
I installed a Vapor on my Baghira. Got everything working 'cept for the fricken Tach. E-mailed customer support and they sent out a new RPM sense wire that had a resistor in line..... Tried it wired to the coil, and on the spark plug line. Both still get intermittent readings. Where is yours wired and what settings in the Vapor setup did you use to get it working properly??
Jose Soriano
2003 MZ Baghira
2008 Aprilia Shiver
2008 Harley Nightster
2000 Kawasaki Concours
2002 Honda XR400R
2008 Genuine Rattler 110
1974 Vespa Rally 200
1963 Vespa GL 150
amahoser
Re: Vapor Settings?
Postby rodge70 » Fri Sep 19, 2008 10:41 am
i wired the resitive wire to coil,think it was neg side,will have a look later.just checked settings of vapor as well 1ppr for step 1 then step 2 is 0000 step 3 should not appear as 0000 was entered at step 2.
1870 if using 17" wheels gives a very accurate speed compared with a gps. if using the dash kit you need an extra warning light for temp though vapor can be set for norm and max temp readings,hope this helps,now off out to enjoy the sunshine :D
rodge70
Re: Vapor Settings?
Postby keithcross » Fri Sep 19, 2008 2:55 pm
Try taking the tacho wire and connecting it to the spare terminal on teh CDI unit (funnily enough marked Tack I seem to remember) Works well on my Acewell unit.
Re: Vapor Settings?
Postby amahoser » Sat Sep 20, 2008 2:01 am
Thanks! I'll give it a try!
Jose Soriano
2003 MZ Baghira
2008 Aprilia Shiver
2002 Honda XR400R
1963 Vespa GL 150
amahoser
Re: Vapor Settings?
Postby BRAAAP ! » Thu Jul 23, 2009 3:25 pm
I'm trying to get the RPM to work (no resistor wire ordered at the mo) did this system of wiring straight to the CDI work ?
(I bet I will have even more questions soon :-D )
Cheers
Ed.
two wheels good, four wheels bad. . . .
BRAAAP !
Re: Vapor Settings?
Postby rodge70 » Sat Jul 25, 2009 1:05 am
hi ed,i tried the wrap wire round the coil lead first but erratic readings at any revs,get the raptor resistive wire and wire direct to coil,see above post,and all worked fine.
rodge70
Re: Vapor Settings?
Postby BRAAAP ! » Sat Jul 25, 2009 2:02 am
I attached the red wire to the neg side of the coil and black wire earthed. . and doesn't seem to be too bad (only garage tests at the mo')
What is actually in the resistor wire ?, I think it costs over £10 ?. . .(plus P&P)
I've got an extra power wire (same fitting on the end) that came in the kit and I guess I could make a resistor wire with a quick trip to maplins. . dya reckon its easy to do ?
BRAAAP !
Re: Vapor Settings?
Postby rodge70 » Sat Jul 25, 2009 1:12 pm
not sure of cost as trailtech sent it foc,hard to telll exactly whats inside it as well but once set up i think my yellow light comes on at about 1500rpm below redline then when red light comes on you know your near rev limiter :wink:
rodge70
Re: Vapor Settings?
Postby BRAAAP ! » Mon Aug 03, 2009 3:41 pm
What settings did you enter for the RPM change light and red line value ?
also did you set the temp values as well ?
Getting there. . . .slowly :-)
BRAAAP !
Re: Vapor Settings?
Postby rodge70 » Tue Aug 04, 2009 3:37 am
will dig the manual out today and check what settings i used and post later
wheel 1870,ppr1,pulse 0000,high temp 80c yellow light,90c red and shift light 6000rpm with 7000 turning the red light on and then the rev limiter comes in shortly afterwards,hope this helps.
rodge70
Re: Vapor Settings?
Postby BRAAAP ! » Tue Aug 04, 2009 2:58 pm
Cheers Matey, info most gratefully received. . . :-D
I tried the bike the other day without a resistor wire and the rpm warning lights set wrong. . . The unit lit up like a christmas tree. . :smt005
(I Have read on a raptor forum that the resistor needed is 6K ohms)
time to disappear into the garage once more. :smt006
BRAAAP !
Re: Vapor Settings?
Postby Pedros_Panther » Tue May 03, 2011 4:12 pm
Hey all,
I'm looking at getting the Vapor for my Baghira. Currently trying to figure out what parts I need. I will be getting an indicator dash with it so no need for the other mounting hardware, right? Does anyone know what size hose sensor to get for temp?
Thanks and Happy Trails!
Pete
Pedros_Panther
2000 MZ Black Panther
1992 Suzuki Bandit 400
Pedros_Panther
Re: Vapor Settings?
Postby rodge70 » Wed May 04, 2011 8:22 am
think it is the 3/4 sensor,i know i needed nothing other than the box it came in apart from the resistive wire for tacho.
fitted temp sensor on pipe next to cylinder near the fan i think,if the tank comes off soon will confirm position,remember chopping about an 1" of pipe out to fit it.
rodge70
Re: Vapor Settings?
Postby Pedros_Panther » Wed May 04, 2011 12:50 pm
Thanks Rodge!
Did you buy the Vapor generic kit or did you buy one for a specific model? Obviously they don't have one set up for the Baghira so I'm thinking I should just get the generic kit for conventional forks, water cooled. Size of temp sensor would be the only thing to confirm but it sounds like I should go for the 19mm?
Thanks again for the support,
Pete
Pedros_Panther
Pedros_Panther
Re: Vapor Settings?
Postby rodge70 » Wed May 04, 2011 3:52 pm
hi pete,just found the box it came in,sticker reads,022-pda vapor dashboard and indicator lights.mz warning lights fit into unit with no mods to loom, i just added an led for the temp warning light.cheers
rodge70
