thermal fan switch
thermal fan switch
Postby hb1rd » Sat Jun 28, 2008 9:39 pm
I looking to replace my thermal fan switch in my 660 skorpion traveller was wondering if anyone knew what would work for my application or the dimensions thread size and temperature setting used
hb1rd
Re: thermal fan switch
Postby Bill Jurgenson » Sun Jun 29, 2008 2:44 am
unscrew yours. The temperature is stamped on one of the hex facets. take that to your local car parts jobber and get one like it. It is a standard car part.
The last one I got from my friendly MZ dealer said Opel Omega on the box.
Postby hb1rd » Sun Jun 29, 2008 9:59 pm
Thank you for the advise but I have already tried this and have not found a match.I live in the states and they have not sold opels since the seventies
hb1rd
Postby Bill Jurgenson » Tue Jul 01, 2008 12:17 am
that was just an example. The switch is used in lots of cars. threads are standardized and usually M10x1mm.
Postby hb1rd » Sun Jul 06, 2008 9:51 pm
Thank you that what I really wanted was the size and thread specification
hb1rd
Postby Bill Jurgenson » Sun Jul 06, 2008 11:13 pm
and what does my previous posting say?
M10x1
85º C.
And why, since you
didn't you simply measure it and look?
Postby handsomejackuk » Tue Jul 15, 2008 3:32 pm
does baghira have one or two fans because i remember someone saying a while ago that it has two....mine only has one !!! could i fit an aditional fan to mine ?
is therer any point ?
Jak
Postby Fil » Sat Jul 19, 2008 1:32 pm
My Mastiff only has one. I wouldn't worry about fitting two mate, unless maybe you have a highly tuned motor that might run a bit hotter?
Fil
Postby DAVID THOMPSON » Sun Jul 20, 2008 2:03 pm
my rt 125 fan has ran 2 times in 5 years both 95 plus f stalled in traffic
i plug the fan into a battery and run it about 3 times a year to keep the grease hot
and make sure it will still run when needed
