Keys
Keys
Postby pamonster » Mon Jun 16, 2008 3:52 pm
Has anyone had a problem getting a spare key made. My bike only came with one and I went to Lowes and Walmart and neither could copy it. Does anyone know what blank works if any at all and or where you had luck getting an extra?
2001 MZ Baghira-Black Panther
pamonster
Re: Keys
Postby DAVID THOMPSON » Mon Jun 16, 2008 5:31 pm
some buell blanks are same
if you know the cut number grahams in uk may be able to get you one
or blanks but get a pro locksmith to cut the new ones take key and blanks and the bike
i had a fit getting some new ones for the saxon tour cut guy had to take the lock apart
keykey keyskeys
BELOW FROM NOTES ON MY COMPUTER
Mz Key Blank Interchange
MuzTruckstuff on Thu Jan 17, 2008 5:57 pm
Did a little additional research on the key thing (hope this is the last post on it). Here's an interchange on the different bikes that use the same key as the Baghira/Mastiff. You can either source a key blank through a brand dealership or use the Ilco blank #X270-TCM1 via this list. This is just for information I got off the Ilco website. Paul
Ilco X270
Ilco EZ TMC1
Silca ZD24RDP
Aprilia
1996 - Present Motorcycles and Scooters.
BMW
2007 G650 XCountry, XChallenge, XMoto
1997 - 1999 F650 (Aprilia)
Buell
2000 - Present Blast
2000 - Present Firebolt
2003 - Present Lightning
2006 Ulysses
Cagiva
99-up
Derbi
1999 - Present. Most models.
Italjet
1996 – up
KTM
1996 – up
Malaguti
1994 – up
Moto Guzzi
1995 – up most models
MZ
1994 – up
Piaggio
Triumph
1997 – up Most models
Yamaha
1997 – 2001 Zuma scooter
Re: Keys
Postby amahoser » Mon Jun 16, 2008 8:22 pm
Just confirming David's post
I got a key cut from a local locksmith and the key blank he used was Silica ZD24RDP
Jose Soriano
2003 MZ Baghira
2008 Aprilia Shiver
2008 Harley Nightster
2000 Kawasaki Concours
2002 Honda XR400R
2008 Genuine Rattler 110
1974 Vespa Rally 200
1963 Vespa GL 150
amahoser
Re: Keys
Postby pamonster » Tue Jun 17, 2008 9:01 am
Sweet, thanks! There's quire a few more options than I thought there would be, should be able to get something worked out with that!
pamonster
Re: Keys
Postby Sue » Tue Jun 17, 2008 3:39 pm
Thanks for the info... was thinking I should get a spare cut :D
Sue
Re: Keys
Postby Linegeist » Tue Jun 17, 2008 4:15 pm
Hells teeth! This place is an absolute mine of information, isn't it? :-D
Right, I'm off tomorrow morning to see the village lock-peasant and see if the varlet can manage to manufacture me a spare set also. :lol:
Brilliant stuff!!
Linegeist
Re: Keys
Postby MJ310 » Tue Aug 30, 2011 4:00 pm
I had a spare key cut here in the UK, it's a fairly common type so had no problem, I will try to find out what blank type it is and if it's still a problem I can probably send you out one.
Mick
MJ310
Re: Keys
Postby DAVID THOMPSON » Tue Aug 30, 2011 4:44 pm
the blanks seem to be out there..
its a problem of having a good original master to cut from
at least here in the US
lowes lumber has a blank i think its for a Volvo car
and if your master is good it will work ok
harley dealer has blanks for buell they work
Re: Keys
Postby Norman Wade » Wed Aug 31, 2011 10:57 am
Here in the UK it's very easy to get spare keys cut. We can get them in high street keycutters (Timpson, Mister Minit, etc) by asking for a 'Silca ZD16RP'. These are fairly common on other European motorcycles, so it might be worth asking in dealers for these. Silca keys are made in Italy, so I assume the blanks are fairly readily available throughout Europe.
While we're on the subject, spare keys for the Hepco & Becker luggage used by MZ are available as 'Silca LS13'. These are plain metal keys (no plastic handles), but are a lot cheaper than H&B keys.
Norman
Norman Wade
Re: Keys
Postby DAVID THOMPSON » Wed Aug 31, 2011 5:33 pm
WARNING
the switch unit for these bikes has been known to come loose from where its mounted
inspect yours regular
it will jam up the steering
see this link for details
viewtopic.php?f=12&t=5291
