trail tech vapor
trail tech vapor
Postby handsomejackuk » Mon May 12, 2008 9:39 am
Phoned Trail tech today to find my local Trail tech dealer. went up to visit him lgracing in pontrilas. Anyway, currently thinking of getting one. Have to save the pennies 1st though roughly £100. with temp indicator, rev counter and the dash part to fit the indicators neutral switch and main beam light. The guy there was very helpful with fitting advice etc.
Rodge, I know youfitted yours did the hole in the dash assembly match the holes in the tail tech ? i.e. is the spacing the same any chance of a close up on the dash and how you fitted the water temp sensor.
Thanks Al.
Re: trail tech vapor
Postby rodge70 » Fri May 16, 2008 3:12 am
sorry al i'm in north wales fitting a boiler so no bike to hand :( and brill weather just to add insult to injury.temp sensor fits just below oe one,under/side of tank,as for the top mounting quite sure i used all the orignal mounts etc as i made a stainless plate to carry the head and extra light for water temp as t/tech lights were all used up,remember to ask for the raptor resistor wire as well for rev counter and wire straight to coil. should be home on monday and have the week off as well,need to sort the mower for next weekend,so if your free pop round,cheers.
rodge70
Postby MUZZIE » Fri May 16, 2008 2:38 pm
handsomejackuk wrote:Hi,
Thanks Al.
HEY BRO,YOU CAN PICK THEM UP OF E-BAY WITH ALL SPARE PARTS NEEDED :D
MUZZIE
