The Paioli RSU fork is much better than many others, even if it is not adjustable. Don't fool with that to start with.
Get a modified CDI or have the one you have modified to at least 8400 and change the gearing to at least 41 at the back if that hasn't already been done. While you're at it, reverse the shift pattern to first gear up: simply stick the change lever on the trans shaft the other way round. Better yet, get an XT shift lever and stick it directly on that shaft.
- xt_lever.jpg (69.94 KiB) Viewed 6061 times
Fit decent clipons under the triple tree and, if you are running the stock carb, the single wire Tommaselli short stroke gas grip; the stock carb does not need the two wire set up at all.
- Ducati Griff -Toy.jpg (67.42 KiB) Viewed 6060 times
Gilles GP Light Clipons with that Tommaselli grip, Ducati on/off switch, and Brembo PS16 pump.
And very first of all if it hasn't already been done, throw the Grimeca shit away - as far as you possibly can, all of it.
Ride the thing with the new CDI and shorter gearing and learn to ride smoothly; shop for the right wheels without getting stressed.
Next, mount a really good strut -Wilbers or Penske or WP made to order, giving them your weight, the total weight and the usage (track). If and when you order that strut, order linear springs for the fork to go with.
First things first and that means good wheels once you have mounted the best strut you can get. The Mito does not have good wheels (Grimeca again!) nor is there any other advantage in using them as they are the same size. The RS125 has downright crummy (Grimeca yet again!!), heavy wheels and the chain is on the wrong side, too. Aprilia RS250 (AKA SUZI RGV) would be fine, tho, and are a common choice. Only for racing, tho, since most 2-stroke wheels don't have a cushdrive.
You need a 3,5" front and a 4,5" to 5,5" rear, not wider.
Here again, R6 is probably easiest. Best would be FZR400 or even better very late TZ250RR 3MA. Scarce as hen's teeth but not impossible. For the front almost any FZR. I can offer a FZR Bembo 3,5"/17 front skimmed down to fit the fork. was used in a TZ250 before I bought it and I used it for the rain tire. Virtually all Yamaha Wheels are Brembo wheels: Brembo belongs to Yamaha!!
All this assuming you are unable or unwilling to fork out for new racing wheels. If you can, go magnesium. Easiest is then Dymag who will deliver plug an play for the Skorpion. I used Marvic myself.
When you get this far and
know the lowly Paioli fork is holding you up, then look into that problem but not before. as you can see above, I still had the RSU mounted in that bike and I know Chris Hunsicker does, too.
Both an early R6 RSU and the Kawas 400 RSU fit the triple tree, both are adjustable and for both it is easy to get springs. I have the KAWA fork complete which I could sell. The KAWA normally has a 3,5" front wheel and 280mm dual rotors.
For later USD forks, you need to adapt the triple tree or have one-offs made to fit. The Aprilia RS125 is definitely NOT the one to choose.
Most any 50 - 54mm will do: FZR, Ducati, you name, but it is NOT plug and play like using a 41mm RSU is and the 50mm USD has 41mm tubes just like your lowly Paioli does. I have personally fit a Paioli USD and a Showa USD (from Aprilia Tuono) using the triple trees belonging to those forks and my own bike has one-off billets. For the stock triple trees, you have to change/remachine the steering tube to fit and this is not a "basement" job.
here is the Showa with its Aprilia trees and new, shrunk-in tube which I made from stock and with PVM 3.5" front wheel mounted
- put_together2.jpg (69.53 KiB) Viewed 6057 times
one advantage of using a modern fork is definitely the possibility of mounting a state-of-the-art caliper like the Brembo P34 with 4 individual pads.
The other Brembo with 65mm bolt pattern is not as good as the P30/34 you can mount on the stock fork, so don't.
this is the one to use:
obviously, the one for the right side, tho.
