Loctite
Loctite
Postby Bill Jurgenson » Fri Jan 25, 2008 12:01 pm
have added a page to my blog with the important Loctite data sheets.
http://cembalobill.blogspot.com/
Re: Loctite
Postby hb7 » Tue Jan 29, 2008 3:32 pm
hello..
Loctite 514 eliminator - hard hi temp : Is this same/similar to Yamabond ?
Where do you use these ?
Loctite 598 black xtremeflex to 260º
Loctite 5926 Blue silicone!!!!!
Why not just use one of them...is my question ? They are very similar.
regards,
henri
hb7
Re: Loctite
Postby Bill Jurgenson » Tue Jan 29, 2008 11:47 pm
I have never seem Yamabond, and I no longer use 514 or 598 but they do work.
I use 5926 exclusively for all motor joints including those that require a gasket; I do not use gaskets at all except for the chain tensioner - and of course the cylinder foot and head.
bare joints:
crankcase and camshaft cover
gaskets
both side covers, starter gear cover.
Those with O-ring obviously use ther O-ring, but I have once put the waterpump cover on without an O-ring, using this stuff and filling the O-ring groove entirely.
Works fine and forms as it were the O-ring.
I have used the 5920 Hi-Temp stuff for plain soft copper head gaskets. While these work fine, they are critical and I do not recommend their use. They are NOT an out-of-the-box solution. I get them from Lany at when I do use them.
http://www.coppergaskets.us/
Re: Loctite
Postby hb7 » Wed Jan 30, 2008 12:02 am
Very good to know, I'll put that to good use.....any reason to use the stock
headgasket when you can get a copper one ?
hb7
Re: Loctite
Postby Bill Jurgenson » Wed Jan 30, 2008 12:51 am
like I said, copper gaskets are not ready-to-use-out-of-the-box. Their use must be understood, learned and this is, at least potentially, an initial source of headaches and problems.
I would definitely stick with OEM for stock bore and brand-name (e.g.Cometic) head gaskets for overbores. Even I do that.
b
