Skorpion swingarm chain protector......
Postby hb7 » Sun Dec 24, 2006 11:58 pm
Anybody figured out a better solution ?
The stock chainguard is soft and can wear through quickly...
Post a picture if you have a figured out a durable fix.
Thanks,
henri
hb7
Postby DEmark » Tue Dec 26, 2006 7:03 am
At a cost of $9.95 each (back in '02) a replacement swingarm protector seemed like a real deal. I only replaced one in 47k miles. I think that was the only dealership part I ever bought for my Skorpion....
DEmark
Postby hb7 » Tue Dec 26, 2006 1:10 pm
That tells me ....you kept your chain properly tensioned.
If you allow the chain to get a little slack, it eats them alive....
The theory is too run slacker for less friction....but, i'm cured of that idea now.
hb7
Postby Bill Jurgenson » Wed Dec 27, 2006 1:37 am
and if you do that, following the data stuck on the side of the swingearem, you need more chains than protectors. Which cost more? Not even considering the wear to the transmission shaft bearing...
More slack doesn't mean less friction, but there must be enuf slack at all times.
chain
Postby basser23 » Wed Dec 27, 2006 11:20 am
So Bill,
What do you recommend for slack? Mine seems quite loose....40mm?
Chip
slack
Postby Bill Jurgenson » Wed Dec 27, 2006 12:15 pm
hard to give a definite measurement. If you are light in weight, never have a passenger and still have the stiff original strut mounted, then the 25mm noted on the swing arm whould be OK.
I have around 40mm as you guessed but have a Wilbers (Technoflex) strut.
The only way to test is to push the tail down as far as it will go: 2-3 guys, best not lightweights, packed onto the seat should do the trick. The chain can then be almost taught. Once you've got this setting, you can measure the slack on the unweighted bike and note it.
Better too slack than not enuf, as long as the chain won't come off like a bike derailleur, it's not too slack. Just a little too taught will pull the chain tight when going over a big bump for instance and this really gets at the shaft bearing behind the sproket. It will also pop of the rollers from the chain in no time.
Couple of other points, too: inexpensive (elcheapo!) stamped chainwheels are very often not round, so you have to turn the wheel full circle to be sure. Only high quality machined aluminum cahinwheels are really round. They are worth the money and usually last just as long as steel ones.
I already noted that anything but the best chain is money thrown out. A really good chain lasts longer and runs more freely; the difference can amount to over a PS.
Don't use the white, sticky so-called lubricant garbage. All that does is bind the dust from the road to make a super grinding paste and wear out the sproket and chain in short order. Unfriendly people go as far as to maintain thet the stuff os pushed by the dealers exactly because it ruins everything so fast. And it positively is an absolute mess.
Clean the new chain first and just oil it with bicycle oil. Do it often. Only takes a minute or two.
The various Teflon dry lubricants are apparently pretty good, too. I have no experience with them, so I cannot say for sure, but they at least do not create grinding paste.
Personally, I ride unsealed chains with a clip lock, as a rule DID ERT2, and oil it weekly, even daily if I am riding an awful lot. On the track, each time out of the pits.
chain
Postby basser23 » Wed Dec 27, 2006 12:47 pm
Bill,
I'll have to measure mine...I am about 175lbs,the bike has shorter dog bones to lift the rear,and a single seat (sport cup)..last time I think it was
about 40mm...it could stand new chain anyway....dont know when it was last changed, do know though it is an o ring chain tsubaki I believe..
Something to do this weekend...
Chip
Postby hb7 » Wed Dec 27, 2006 1:36 pm
I'm going to try and keep it at 35-40mm slack....until
I make some sort of 4mm HDPE (cutting board) chain protector for the top of the swing arm. My plan is always to run maximum miles with minimal stupidity.....
Interesting statement : Alu chain wheels can last as long as
the stock steel chain wheels. Are you talking about 25K miles ? Stock 'milk chocolate steel' chain wheels barely last as long as the chain.....
hb7
Re: Skorpion swingarm chain protector......
Postby project1225 » Tue Dec 13, 2011 6:04 pm
I hate to revive a dead thread as my first post, but here it goes.
PS- Thanks to everyone who has given input on these boards... I've been lurking for about 6 months (purchased my MZ Skorp in April of this year), and this board has saved me more than once!
The other day I noticed a strange noise coming from my front sprocket... upon inspection, it would appear that my swing-arm protector has given up the ghost (38k and 11 years old, I suppose it was time). After doing some research, I have found a part number from Grahams in the UK: http://www.grahamsmotorcycles.com/2010% ... ng_Arm.htm # 13 on the page, part no. 3426026000.
Does anybody know where I can purchase one of these in the US?
Thanks!
project1225
Postby basser23 » Wed Dec 14, 2011 11:59 am
try using a piece of ribbed auto timing belt glued onto the swing arm....most repair shops should have a bunch lying around.
Postby Old Dog » Sat Dec 17, 2011 3:37 am
If you cannot get one stateside, I am sure Graham will ship but in the unlikely event that you are stuck drop me a pm and I am sure we can sort it out.
Have you tried a Yamaha dealer, the swing arm is a Yamaha item?
All the best
Old Dog
Old Dog
Postby hb7 » Sat Dec 17, 2011 11:01 am
Better off making your own, stock chain guard is made out of cheese like rubber.
they don't last very long...in my experience. I have ridden some ~75k miles on Skorpions.
Henri
http://moto-science.com/
hb7
Postby project1225 » Sat Dec 17, 2011 9:10 pm
basser23 wrote:try using a piece of ribbed auto timing belt glued onto the swing arm....most repair shops should have a bunch lying around.
Better off making your own, stock chain guard is made out of cheese like rubber. they don't last very long...in my experience. I have ridden some ~75k miles on Skorpions.
I thought about using a timing belt, too... but will it hold up to such constant metallic wear?
As for the actual protector, Graham's wanted about 20 GBP for the protector including shipping to the US, which is more than reasonable all things considered... but if something more robust can be made for less then perhaps that is the answer.
project1225
Postby hb7 » Sun Dec 18, 2011 1:53 am
It's not worth 20 GPB.....sorry. The stock rubber is soft like cheese.
I know, I have done 75k miles on Skorps. Better to make your own....
hb7
Postby basser23 » Sun Dec 18, 2011 10:31 am
used timing belts are free....just some glue and bingo you're good to go...make 3 or 4 from the belt to have spares,who cares how long they last right?
