keithcross wrote:Put the tuned motor you have in the sport. Get the hotter motor in the BaggiLots more fun to be had that way.
BTW the CCM R30 uses the same wheels, spacers needed, remove shims from rear wheel bearings to fit baggi rear spindle. Havent tried the front yet, but should be easy-ish. You will need different discs though as fixing centres on ally whels is different. CCM uses smaller rear disc and 320 front.
tuny wrote:finaly i allmost finiched the mastiff here a pic by night, tomorow i'l make some at daylight. tell me what you think, always open fore other adjustments.
