Thanks, I'll know who to ask when I add lights, if I need help with the relay and so on.
My application is probably quite different; a lot of urban or semi-urban freeways without much traffic, where I use high beam - because I need it at 120kmh - but I sometimes need to switch to low beam because the barrier or hedge or whatever is not enough to stop it bothering people on the other side or it's too much for the cars I approach from behind.
In the city, I keep noticing that the sportbikes - and the modern scooters that look like sportbikes from the front, the better ones, I suppose - have really bright, big visible headlights.
A while ago, when I was buying stuff for my R100GS project, I read all these reports/tests that said that the Osram Silverstar and the Phillips VisionPlus were the best, and I got one of the Phillips VisionPlus bulbs.
Then when I got the Baghira, I thought the headlight seemed quite good, but I thought I'd put in the VisionPlus and see how much better it was. Well, it turned out that that was what the Baghira came with!
Another good quality part on it.
There's no deer problem here, just non-reflective people that sometimes walk into the road - we have a very high pedestrian death rate here. But we certainly have the possibility of stones and potholes on the secondary roads.
