I can't get my turn signals to work?!?
Postby baroquenride » Fri Mar 17, 2023 8:43 pm
So my turn signals used to work, but went out...as in nothing works anymore. I can't figure it out. The 7.5 amp fuse blew so I replace it, but they still don't work. I've pulled the relay, tested it using this video: https://youtu.be/HdERp5e78eM and it works properly so now I'm stuck and not sure where to look.
baroquenride
Re: I can't get my turn signals to work?!?
Postby Puffs » Sat Mar 18, 2023 3:32 am
Postby baroquenride » Tue Mar 21, 2023 9:58 pm
So I started in again today and began using a multimeter continuity test. Long story short, I discovered a broken 3A fuse. Despite there being a label of the fuse sizes on the inner fender, it doesn't say what is for what. Regardless, I swear that I checked each fuse for continuity and the 7A fuse was discovered bad so that's what I was focused on. I knew it was fine after replacing it, the relay was fine, and all the other fuses were fine.....nope. Anyway, I replaced the 3A fuse, discovered a broken ground in one of the turn signal wires after 3 of the bulbs were working and fixed that final problem. Now it appears the turn signal circuit is working again.
baroquenride
Postby fish » Sat Apr 29, 2023 5:53 pm
Congratulations. I hate electrical problems. Glad you fixed yours.
A friend of mine fixed his malfunctioning turn signals by cleaning all the contacts in the headlight shell.
fish
