What is the best true Supermoto style suspension setup for the street
either stock or custom one off
phlat65 wrote:I have the stiffer springs already, I think a re-valve would be in order, but I don't see how valving can affect the first 1/3 of travel. there are slots cut in the damper tube that allow oil to flow out freely at the bottom 1/3 of the stroke. the valving then takes over dampening control after the piston passes the end of the slot. I thought about makint a slieve that partially covers the slot to make tha valving work for all of the fork travel. I guess I need to talk to the suspension tech to see if I am right....
Users browsing this forum: Bing [Bot] and 9 guests
