Testing CDI unit
Posted: Fri Jan 13, 2023 8:09 pm
Hey folks.
I've just got my hands on an MZ powered Tigcraft Supermono bike that hasn't moved in 30 years, and have been going through it getting ready to (hopefully) start it up. The bike literally last ran in a race then was put in the garage and remained there until I pulled it out and put it in a van.
The question I have is about the ignition box. There's really very little wiring on it at all.
Total loss system, so a battery, a coil, ignition pickup, a kill switch, and the 'black box'. That's everything.
I've tested the igntion pickup and get correct resistance reading, and also tested the coil and both primary and secondary windings give correct values also. When I connect a battery, power goes through the kill switch and the coil also powers up - so far great news.
I'd like to see if anyone knows if its possible to test getting a spark. Some bike's I've had, when you have ignition powered up, then flip kill switch, the coils discharge and you get a spark. Not so on this bike, so are there any ways I can test getting a spark without cranking the engine? There's no charging system, no starter motor, nothing. Perhaps bridging the wires from the pickup for a moment would do it, or is that a stupid idea?
I tried putting the bike in gear on a stand with the plug out resting on an earth point and turning the engine over by rotating the back wheel - no dice.
Likely to be fitting an TCIP unit but would ideally like to get some noise out of it before deciding what to spend the money on.
Any advice appreciated.
