Problems cold starting 660
Posted: Sat Feb 11, 2006 3:25 am
Hi
My black Panther 2002 is has problems starting when less than 8 deg C.
I bought it used one year ago. It has race can and "maybee" carb modifications. The previous owner didnt know for sure. Her is a description of the problem:
The choke is very sensitive. To start (cold in summer time) i always have to have full choke and then turn it completely of 3-5 seconds after it has started. Otherwise the engine stops again. When the engine is hot i can run it with the choke on again if I wanted to.
Now when the temperature is around frezing point it wount start at all. Around +5degC it may start but only if I give it just a litle bit choke. then If I am lucky it will idle for a minute until i can start to ride it. If I touch the choke or give it som revs it stalls again.
It semees to me that the engine is very sensitive to the fuel/air ratio. Why it doesnt start on full choke I have no explenation. The normal reason i suppose could be that it is to leen mixture ? But then full choke should solve it ?
By the way, if I use start gas from a can it will start even below freezing temp.
What should I do ???
