JT700 wrote:Is the engine in the Baghira more closely related to the Yamaha Raptor or the Grizzly in terms of carbeuration, drivetrain, internal components, etc. The reason im asking is im looking at raptor and grizzly clutch, carb, exhaust, and maintenance parts (oil filters, air filters) and things of this nature, and wasnt sure what i should look for.
keithcross wrote:The UK Dynojet dealers sell a carb kit for the MZ and XTZ carbs, bigger jets, new needle and a few other bits.
Hope this helps.
F0ul_Oli wrote:The big diffrence is the Titanium valves on the Raptor - connected to a different fueling ECU gives you an 11000 rev limit - and that is where the extra power can be found!
Not sure if doing the changes on the Baggy would make it ridable though!
F0ul Oli
JT700 wrote:http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=&store=Main&catId=403&productId=p447491&leafCatId=40301&mmyId=
#448812 might work if the mid pipe is long enough, then i would have a nice pipe that fit right up under the rear fender. and its cheap too!!!
Users browsing this forum: No registered users and 170 guests
