e wrote:The Baghira seems pretty peppy to me...but I thought I should ask anyway: Does the Baghira need uncorking?
AndyDent wrote:e wrote:The Baghira seems pretty peppy to me...but I thought I should ask anyway: Does the Baghira need uncorking?
I had an exchange recently discussing fuel economy with someone who's jetted up their Skorpion Sport - for what gains they have in performance they have lost at least 30% of their fuel economy.
I'm getting around 60mpg with about 50% freeway riding.
roge-a-billy wrote:Dynojet do a re-jet kit for the XTZ660 Yam' carbs, about 88 English pounds. That with a better pipe and opened up airbox, set up properly would do it a world of good. All depends how much you want to do / pay for.
dmon722000 wrote:Remove the EVAP system, that helps starting and throttle responce too
dmon722000 wrote:If your overseas (not in the states) your bike may not be equipped (no dastardly EPA over there) As far as drilling the jets goes.... sure its as basic as that I suppose, but I shy away from that personaly. I run a 132 main jet in the primary, for a few dollars (pounds), I'm sure you can get it done right. Also, the jet as no great affect on the "atomization" of the fuel, thats the job of the emulsion tube and needle (with their male/female arrangment takes care of all that (combined with the vaccum signal from the downward stroke of the piston)). The jet is just the gateway for the raw fuel charge entering the emulsion tube. Well have fun in your project, whatever you decide will more than likely be adiquate. My settings at sea level are:
* 132 main jet (primary)
* stock secondary jetting, was flooding too easily in slow "creeping traffic"
* Secondary carb adjusted to "come on" at 5mm or primary carb travel
* Air screw set at 5.5 turns from bottom (at sea level)
Works great all the time, every time.....
Users browsing this forum: Bing [Bot] and 10 guests
