by cat » Wed Nov 30, 2005 9:01 am
I'm probably going to get a 2003 SM soon and I've been reading all the posts here. I still don't know what exactly the carbs are (Teikei, both of them?) / what rebuild kits (diaphragm, o-rings) to use. ...?
cat
by F0ul_Oli » Wed Nov 30, 2005 1:39 pm
they are exactly the same as the one for a Yamaha XTZ660 - that is the easiest way of getting the kit you need!
Hope this helps
F0ul Oli
F0ul_Oli
by DAVID THOMPSON » Wed Nov 30, 2005 6:05 pm
cat you gave no location
so if your in the usa try this company
i have never used them
but they may be able to help
http://www.carbparts.com/
ar dave
- Moderator
by cat » Fri Dec 02, 2005 7:46 am
DAVID THOMPSON wrote:cat you gave no location
http://www.carbparts.com/ar dave
South Africa.
yes, SUDCO or carbparts, or Yamaha dealers, but it's better if you know the actual carb model/size.
cat
