Re: skorpion carb
Re: skorpion carb
Postby dellboy77 » Fri Mar 13, 2020 5:51 pm
Skorpion carb help please pipe work
Looking at carb from air box side where fuel
Goes in pipe above is that just a overflow
( no pump fitted )cheers del
time is not important its the importance of time
dellboy77
Re: skorpion carb
Postby dellboy77 » Sat Mar 14, 2020 1:18 pm
Pull my carb off cant fine any problem
But there must be ?
The bike starts first time every time tick over prefect
When going runs well till
I start to slow down fill like it starting to run out or petrol never
Cuts out open throttle again pick up prefect ?
dellboy77
Re: skorpion carb
Postby Puffs » Sun Mar 15, 2020 5:36 am
It's a riddle, yes?
Maybe the level in your float bowl drops, combined with a rich high & a relatively lean low & mid-speed jetting. Check the long-term flow from your fuel pipe into the bowl. Tank vent?
Re: skorpion carb
Postby dellboy77 » Wed May 27, 2020 11:57 am
when out today first ride since lockdown put another carb on same problem need to know where pipes go on carb after pump remove please thank again tank vent clear
dellboy77
Re: skorpion carb
Postby breakwellmz » Wed May 27, 2020 5:44 pm
The well hidden filter under the float valve maybe?
Re: skorpion carb
Postby breakwellmz » Wed May 27, 2020 5:45 pm
viewtopic.php?f=3&t=10435
