Baghira rear disc 17”
Postby Blue » Sun Sep 29, 2019 8:29 pm
Hi All,
I’ve searched for a while in the forum and online but can’t find any info on where to get a rear brake disc. Mine is cracked and I’m in need of a new one. Anyone have any info of where to get an new OEM, used, or different model that works? Literally anything to get ridding again that doesn’t involve a whole new wheel. Or is that my only option?
Thanks.
Blue
Re: Baghira rear disc 17”
Postby Guesi » Mon Sep 30, 2019 11:54 pm
Guesi Motorradteile
MZ spare parts
Postby WernerLE » Tue Oct 01, 2019 6:09 pm
Yamaha XTZ750
I use ECB MD6119 5mm thik,
look for the clearence of the Boltheats !!!
WernerLE
Postby Blue » Tue Oct 01, 2019 7:48 pm
Thanks for the info. And for bolt clearance, is there a shim I can add somewhere? It’s obvious the guy I got the bike from didn’t pay attention to this since the bolts were rubbing on the caliper and damaged both. I had to drill the bolts out.
Blue
Postby tigcraft » Sun Oct 06, 2019 3:01 pm
CCM run on same wheels. Not sure what discs they run although you'll have to check it out.
tigcraft
