Running issues on 2002 Baghira
Re: Running issues on 2002 Baghira
Postby rodge70 » Fri Jan 04, 2013 4:36 am
handsomejackuk wrote:my fuel cap is a lockable item with no tube... it has always been o n there and causes no problem... only thing i have noticed though is ... that there is a squealing noise sometimes in shed when i put bike away.. if i loosen the fuel cap it goes so there must be a vacuum in there... do i need a vent in this locking cap ???
my gpz does the same,more so on a hot day and opening the filler either allows more air in or out not sure which and i suppose that noise will be there when riding but your not going to hear it over the sound of everything else.
never noticed it on the mz but that has a breather dia of about 3mm now i have drilled the pipe holder out
rodge70
Postby handsomejackuk » Fri Jan 04, 2013 1:42 pm
duncmac wrote:Damn, I read you had an acerbis locking cap for yours, I was hoping it had some kind of vent to it.
Is this what you have Image
If so they are ment to be vented somehow, might be worth looking it over.
Jack, do you know what bars you've got on ur baggy?
yeah man that is what i have it was on the bike wheni bought it years ago .. it is nice...
i also have rubber footpegs too at least i did... grrr i lost one last year.. they were real nice too... i had loads of extras on mine blue tops to suspension, rear carrier bit, and bash guard that is nice too..
Postby handsomejackuk » Fri Jan 04, 2013 1:45 pm
ohhh yeah the bars are WRP oversize items they are also nice, i picked them up at Ray hockey racing when they were shutting a few years ago.. they included the clamps they are black anodised items much better that the domino tat that is fitted to the baghira as standard...
dont think i gave a lot for them summut like £40 for the lot.. best thing i ever boughted..
these is the clamps...
about £27
and theses is the bars....
these is about £80
here they is looking nice....
i did have the tension clamper removed for ages but have decided to put it back on now.. for a change and it does look nicer too...
Postby duncmac » Sat Jan 05, 2013 7:58 am
Thanks Jack, I'll take a look at those, once I've got the thing running!
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
Postby breakwellmz » Sat Jan 05, 2013 10:49 am
duncmac wrote:Thanks Jack, I'll take a look at those, once I've got the thing running!
Hi
The lack of a vent has got to be most,if not all of your problem i think.
You can always run it initially with the cap off or loose.
Postby duncmac » Sun Jan 06, 2013 11:51 am
Hi
Its got the original cap with vent hose, will be leave that loose (and checking I can blow through it)
Anyone have any advice on how to get the float pin out? I cant seem to shift it and I dont want to be hammering at it.
Do I remove in the the direction of the arrow? Should I expect to have to wack on it with a hammer?
duncmac
Postby Skorpion660 » Sun Jan 06, 2013 3:02 pm
Do I remove in the the direction of the arrow? Should I expect to have to wack on it with a hammer?[/quote]
Put "float pin" into the search bit of the 660 forum and there's lots of advice.
Whatever you do don't "wack it" as you'll ruin carb.
Skorpion660
Postby Skorpion660 » Sun Jan 06, 2013 3:08 pm
viewtopic.php?f=3&t=4705&hilit=carb+filter+hidden Page 2 of link useful info.
Skorpion660
Postby duncmac » Mon Jan 07, 2013 2:25 am
I had aa look round here and on some other forums for xtz's.
Just wanted to be totally sure that I REMOVE in the direction of the arrow.
Had a dream lastnight where I snapped off the arrowed pin holder, shudder.
I'll borrow some more precision made pilers and have another go tonight. Might try the solder iron heating trick as well.
duncmac
Postby duncmac » Mon Jan 07, 2013 6:15 am
Hmm just seen the seller of my baghira has just put up an exhaust for sale.
Scorpion pipe & link pipe. http://www.ebay.co.uk/itm/MZ-baghira-ma ... 4d08741d1f
Hmmm wonder why he didnt mention he had that when he was selling the bike to me.
Also these wont fit a baggy, seller should know better really. http://www.ebay.co.uk/itm/MZ-skorpion-s ... 4d08743350
Sigh...
duncmac
Postby handsomejackuk » Mon Jan 07, 2013 2:34 pm
I stripped my carb a few months ago, and cant remember taking out the float pin.. i just stripped them all down, cleaned all the galleries, and put back together.. seeems to run better since....
what i also did was adjust the carb balance so that the secondary carby comes on earlier, and it seems to be loads quicker since...
Postby Nils D » Fri Jan 11, 2013 6:13 pm
I cleaned my carburetor last autumn, and I had to be quiet brutal to get the pin out.
But it was there, behind the small filter that most of my problems where gathered. Then it was time to put the bike into winter storage…
Skorpion Traveller 96
Nils D
Postby Chalks » Mon Jan 14, 2013 4:20 pm
Just spotted these on fleacebay, they might come in handy should the unthinkable happen :cry: item number 261093942265
http://www.ebay.co.uk/itm/MZ-660-CARBUR ... 3cca6963f9
Chalks
Postby duncmac » Tue Jan 15, 2013 6:11 am
Already got my spare set off a xtz660 for £40.
I'm a bit of a spares ebay addict.
Thanks for the spot though!
duncmac
Postby duncmac » Mon Mar 04, 2013 3:52 pm
Finally got the carb back in the bike as of yesterday.
Tank on and added some fuel today, fired up and doesnt appear to have any issues revving up like it was before.
Neutral light is dead though. Every other light, electrial thing works.
Getting the two tubes back on the rear of the carbs, from the airbox was a pain in the arse and it felt like the oil pipe and other stuff was getting in the way.
If anyones got some idea as to what to check through for the the neutral light it would be appreciated.
Anyway it was good to have it fire straight up after being it bits for so long.
duncmac
Users browsing this forum: Bing [Bot] and 15 guests
