Bill, I meant the in specs of the carb :
Needle: 9DZH5-50-3
Needle Jet: P-4
Injection tube: 0.35
Bill Jurgenson wrote:You can order the TM34-B70 for the Raptor which is a plug a play fit and it is also 100$ more expensive.
Doesn't cost me 100$ to modify for myself and besides, when I started this, the Raptor kit was not yet available.
Bill Jurgenson wrote:you need the larger right side hose for the left side as well and of course you have to enlarge the hole in the airbox.
Otherwise no changes at all. The carb fits right into the rubber mounts as it is if bought from Topham since he presses a sleeve on the right carb spigot to fit the mount.
talking about the standard TM34-B65 or 70 (are both the same thing) which is confectioned for this engine. If you order from Topham, you have to say which engine. The same carb for a TT or SRX with not have the sleeve since both mounts are the same.Update : These are not sold in the USA, looks like a Topham exclusive.
"these" being the Raptor kit.
right, Steve makes this modification. Very small volume, so expensive.
