Need airscrew setting help urgent.
Re: Need airscrew setting help urgent.
Postby Srinath » Mon Oct 29, 2012 7:08 pm
I cant see it run like a beast for 20 miles and stall @ the traffic light and not have compression ...
Its sucking through the carb ... or atleast the intake ports ...
Its pushing plenty of gas through the exhaust.
I guess fuel ... and your warnings about isoheet etc etc I have to take as the reason ...
BTW it could have jumped a tooth or 2-3 on the cam chain ... that usually happens on shutting the throttle ... I actually stalled it on the way up @ that traffic light ... let it sit 10 mins, started it back and it ran like a beast to my exit ... where upon it stalled and never started back ...
I have to check a few things ... the gas is my first bet though.
Cool.
Srinath.
Srinath
Postby Srinath » Tue Oct 30, 2012 10:45 am
How do you guys check timing.
I can hand turn it to the TDC and see if valves are fully closed.
I would think that should do.
Also how to check if the ignition trigger is good. I do get spark, but at the right time ?
If I hand turn it with the key on will it spark ? then I can see if it hits @ tdc ?
Cool.
Srinath.
Srinath
Previous
