Alternative pilot jet for uncorked stock carbs.
Re: Alternative pilot jet for uncorked stock carbs.
Postby Srinath » Mon Nov 19, 2012 7:31 pm
edfmaniac wrote:You could do that if you think it's necessary but mine has been working fine installed as is. There's an old saying I was brought up around, "If it ain't broke, don't fix it!", and mine ain't broke. LOL
When I tried it yesterday it seemed to crunch into the carb body.
Cool.
Srinath.
Srinath
Postby edfmaniac » Mon Nov 19, 2012 11:31 pm
If works for you then call it a success. Did the reworked jet fix the problem that initially made you want to swap out the old jet?
Postby Srinath » Tue Nov 20, 2012 10:32 am
edfmaniac wrote:If works for you then call it a success. Did the reworked jet fix the problem that initially made you want to swap out the old jet?
On mine there are issues ... many ...
OK the pilot jet was punched to nearly .46 mm, I think I did that last year somehow mistakenly thinking the 48 is a .48mm. Anyway the bike ran after that though, till spring of this year when it died abruptly ... I worked on it though summer, got it started a few times but it always was hard to start ...
However ~a month ago I started it and ran it till again it died and hasn't been back togther yet ... the corrections of pilot jet and the air screw etc etc etc are all gonna be done as is some more work like deracking and cleaning etc. The carbs look very clean though, however I am not taking that for granted.
So I guess i am yet to know for sure ...
Cool.
Srinath.
Srinath
Previous
