One is a single 42mm Keihin PWK on an intake adapter.
Another one is two carbs 40mm AND 30mm PWK on stock intakes. Had to add 90 degree cable guides to clear the bottom of the fuel tank and modify some throttle cables. It's a very tight fit but it works. Utilizes stock choke cable for ease of use.
They both rip!
