Hi..
Im currently looking to install a 10.75 to 1 piston in my baghira.
I was wondering what the general consensus is on the strength of the standard conrod.
Regards Dean
Dean Driver wrote:Ill check megacycle out.. Thanks for the tip.
My concern with the cam is whats the most suitable.. I believe raptors rev higher than a baghira
So im not so sure a raptor cam would be best suited? Im sure this is something they will be able to advise on.
dandywarhol wrote:Be VERY, VERY careful when fitting a high lift cam that the spring retainer doesn't tangle with the stock valve guides. I'm building an engine with 12:1, 727cc CP barrel/piston kit and Hotcams 3 - it's essential to fit Kibblewhite or similar shorter valve guides, or at least remove 1mm from the stock centre guide. I have K'white black diamond valves and springs to match. The valves have deep recesses to lower the comp. ratio to 10.7:1. I'm also using a Carillo rod.
Users browsing this forum: No registered users and 193 guests
