Baghira Radiator -KTM?
Postby lcrken » Fri Mar 08, 2013 3:14 pm
The left radiator in my 2005 Baghira has developed a leak around the main hose fitting in the upper tank. I've searched for substitutes here, and found a statement that it is from a KTM LC4 640, but the pictures of the 2005 LC4 radiator show significant differences from mine. The lower and upper outlets on the KTM point in different directions from mine, and the fan mount brackets are also different. Can anyone tell me if there is a KTM radiator that is a better match? I'm about to send my radiator off for repair, but I'd really rather be able to buy a new one. Thanks for any help.
Ken
lcrken
Re: Baghira Radiator -KTM?
Postby kman.45 » Wed Mar 13, 2013 10:55 am
lcrken wrote:The left radiator in my 2005 Baghira has developed a leak around the main hose fitting in the upper tank. I've searched for substitutes here, and found a statement that it is from a KTM LC4 640, but the pictures of the 2005 LC4 radiator show significant differences from mine. The lower and upper outlets on the KTM point in different directions from mine, and the fan mount brackets are also different. Can anyone tell me if there is a KTM radiator that is a better match? I'm about to send my radiator off for repair, but I'd really rather be able to buy a new one. Thanks for any help.
Ken
I think the conventional wisdom that they are KTM tanks is correct. But I also have a KTM 640E LC4, 2000, and the radiators are not the same as on the Baggi, although they look very similar so are likely same manufacturer. Sorry can't point you to the right model, but they are not same as the early 2000s 640s
2003 Baghira 660 SM/E
2008 Ducati Multistrada 1100S
kman.45
Users browsing this forum: Blurredman and 12 guests
