I want a Wheelie Monster !
WHEELIES R FUN
Postby hulagun » Mon Dec 13, 2004 4:27 am
Taking Phlats advice, and inspired by my girlfriend watching, I did a perfectly good wheelie using only the loud handle.
From a dead stop (seated midway back on the saddle), rolling forward in first gear, 'slam da frottle' to compress the forks, then as the forks rebounded I leaned back and goosed it good. Up came the bike into my chest, balance point approached and lofted the wheel smoothly as I accelerated... the wheel dropped back down just as smooth on the far side of the intersection. Never hit the rev limiter either. :-D
Felt like bike was vertical so that means wheel was 6" off ground, right? My g/f said it looked "hot" and "the front wheel was way high up"... but then she's trained to say nice things bout me.
I'm guessin that since I brought the bike to my chest I did lean forward... now I am practicing more small wheelies and working on controlling that reflex. :wink:
1978 Ducati 900SS cafe racer
1969 Triumph Bonneville 650
1966 Honda CB160 F160 racer
hulagun
Wheelie monster
Postby Nataraj » Wed Feb 02, 2005 4:26 pm
A couple of thoughts about wheelies on the Baghira:
- the "reduced ride height" model has a shorter swingarm, and therefore lofts the front wheel easier. Some folks here in the States had one of each handy and measured the swingarms...something like almost 2" different.
- first gear wheelies with a stock bike are simple on the "RRH" model, and harder on the other model. Somebody else already posted the right way to get that front wheel up: rolling in first at 10-12 mph, close the throttle to load the forks, then roll on the gas hard. It'll come up!
- I still can't do a second gear wheelie, and I still haven't tried shifting into second mid-wheelie, but spring is coming!
- I'm having a 1mm larger, higher compression piston put in, as well as some flow and valve work done. I'm anticipating 50+ rear-wheel HP, and if everything else stays about the same that should also give me 49-50 fp of torque. Dyno results posted when the work is complete...
Nice t'meet you all. I'm new here. I have some MZ stuff on my website (opinions, mods, etc.) here: http://c_hauser.tripod.com
TTFN!
Nataraj
Ride wha'cha got and quit listening to those nattering na-bobs of negativity who say you can't ride cross-country on 'that bike'.
MZ Baghira SM
Honda 919
Rogue Custom (SR500 in Suz. GS500 chassis)
Nataraj
Previous
Users browsing this forum: Bing [Bot] and 121 guests
