Rear wheel removal?
Rear wheel removal?
Postby DrGonzo » Mon Feb 29, 2016 11:00 am
I know the axle and the nut on the chain side are independent one another but are there some steps I should take in removing my rear wheel or some good tips to make this job a little easier?
I have new tires to mount and am waiting on a 16T engine sprocket so that when I have both I will install them at the same time and lube my chain, etc.
DrGonzo
Re: Rear wheel removal?
Postby DAVID THOMPSON » Mon Feb 29, 2016 11:44 am
remove the clinch bolt on left side ,,on mine the axle is 18mm i think hold nut on right but do not move it
unless you need to adjust the chain
wheel then comes off like a bike with a drive shaft
do watch where all the spacers go :smt023
Postby DrGonzo » Mon Feb 29, 2016 11:48 am
Cool, that's what I needed to know. Thanks.
DrGonzo
Return to 500 cc
