silver star clocks
silver star clocks
Postby stephenh » Thu Jan 19, 2012 1:04 pm
Hi all
i was out for a spin on a silver star[a friends] a couple of days ago when i noticed a problem with the speedometer and rev counter,while i was stationary at a jcn .....the rev counter needle was showing max rpm whilst the engine was only ticking over,and the speedo was showing that i was doing about 20 mph.when i pulled away from the jcn the rev counter needle began to move through the entire rev range of its own accord,has anybody else ever had this happen to them.Any help much appreciated. regards steve
stephenh
Re: silver star clocks
Postby DAVID THOMPSON » Thu Jan 19, 2012 7:59 pm
do a careful check of the electrical wiring harness
bad ground some where
sparkplug wire arcing to tack wire
start it in the dark on a very dark night and look for sparks ????
my rt125 tach went nuts one day the next day it died and i found the plug from the voltage reg unit
was burnt and a big mess
the speedometers most bikes often are an aluminium disc with a magnet in side
it is located close to the tach which may have been putting out big magnet pulses
as the electrical system feed it electric it did not like
i have been working on electric things 60 years and nothing surprises me any more
ALSO SEE THIS
a note on the wiring of Rotax powered bikes.PDF
loose ground wire location
(162.06 KiB) Downloaded 260 times
Postby comanche91 » Thu Jan 19, 2012 11:07 pm
-Don
1-3/4 1995 Silver Stars
comanche91
Return to 500 cc
