Exhausting troubles...
Postby Trogolodyte » Thu Sep 29, 2011 11:02 am
Whilst fetteling Thumper (my 500 country) I have discoverd that the rear exhaust section (from under the carb to the silencer) is very rotten and has lots of holes and patches across even older holes....
I know that sebring do not make replacments and finding a good 2nd hand one is a bit like finding chickens teeth or rocking horse poo. So its time to find an exhaust fabricator who can make up a section of stainless steel to go from under the carb to just behind the rear left shock absorber, where I intend to mount either an aftermarket endcan from somthing like a ccm or a ktm big single Or find a secondhand alloy trials silencer from somthing like a Bsa B40, my dad used to have a B40t and I used to think it both looked nice and sounded nice too. If i do that I will Keep the old pipe with a view to getting somthing simmilar made up at a later date...
Trogolodyte
Re: Exhausting troubles...
Postby Trogolodyte » Thu Sep 29, 2011 11:29 am
Been on the Mtriders club page and there is a very good way of doing what i mentioned above, but using a silencer from a kawasaki GPZ500...
My plan is to use one of these...
http://www.merlinmotorsport.co.uk/EXHAU ... 0e46950051
to go From under the carb to just above the pillion footrest....then may be a pair of these 30' ones,
cut to size and pressed into a flat section to run behind the rear left shock absorber, and the other cut and modded to fit to a universal silencer, I have a Bsa B40t alloy trials silencer that i want to use but one of these should work too
http://www.ebay.co.uk/itm/UNIVERSAL-CUS ... 2a115c7846
Trogolodyte
Return to 500 cc
Users browsing this forum: No registered users and 72 guests
