parts sources new and used
Postby gilerawarren-3 » Thu Sep 15, 2011 11:28 am
I need pretty much everything related to the electric start except the starter itself. I got the c/r seal with the proper spring for my sprag but everything else in there needs replaced. The sprag ollers are rounded, the snap ring that holds the sprag in is badly oval shaped as is the needle brg. The free wheeling gear is gaulded on the sprag surface and the thrust washer is wore half thru. Does anybody have any of these parts used? what would be the best source for buying them new if need be? Ron Woods or?
Cheers Warren
09 Aprilia SR50
08 Aprilia Scarabeo 500ie
07 Ducati GT1000
94 MZ Silver Star Classic 500
73 Citroen GS1220 Club
gilerawarren-3
Re: parts sources new and used
Postby comanche91 » Thu Sep 15, 2011 12:12 pm
gilerawarren-3 wrote:I need pretty much everything related to the electric start except the starter itself. I got the c/r seal with the proper spring for my sprag but everything else in there needs replaced. The sprag ollers are rounded, the snap ring that holds the sprag in is badly oval shaped as is the needle brg. The free wheeling gear is gaulded on the sprag surface and the thrust washer is wore half thru. Does anybody have any of these parts used? what would be the best source for buying them new if need be? Ron Woods or?
Another source I like is American Dirt Bike for Rotax parts http://www.americandirtbike.com/. Ask for Keith. :D
-Don
1-3/4 1995 Silver Stars
comanche91
Postby Trogolodyte » Thu Sep 22, 2011 2:06 am
Coils,
Have found a place on ebay (germany) that can supply NEW sr500 coils. they are the same part (Nippon denso coil), but they have a different connector instead of the three way connector they have a two point one... so some modification will be required.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0371520972
Trogolodyte
Postby gilerawarren-3 » Thu Sep 22, 2011 2:48 pm
Trogolodyte wrote:Coils,
I think you may have replied to the wrong post. I had no discussions about coils
Cheers Warren
09 Aprilia SR50
07 Ducati GT1000
gilerawarren-3
Postby Trogolodyte » Fri Oct 14, 2011 6:14 am
read the title of your thread... it is a source of a new part that works on the Mz rotax bikes
Trogolodyte
Return to 500 cc
Users browsing this forum: Bing [Bot] and 6 guests
