MZ 500 Front brake caliper
Postby vme250 » Tue Apr 13, 2010 1:41 am
Hi
My front brake caliper started leaking, looks like the main seal around one of the pistons. Haven't taken it apart yet.
Does anybody know where to get a seal kit for it??
thanks for any leads
Larry
vme250
Re: MZ 500 Front brake caliper
Postby hmmmnz » Tue Apr 13, 2010 2:49 pm
send these guys a email
http://grahamsmotorcycles.com/
or pull the seals out and have a measure
and order the parts via a grimeeca supplier
"Don't... Don't put the noodles and the dumplings together in the boat. They'll fight! The noodles are bullies. Poor dumplings."
hmmmnz
Postby vme250 » Tue Jul 27, 2010 9:49 pm
Went to the local euro motorcycle shop, he pulled a Brembo caliper off the shelf @$125 it bolted right on works better than the original even with smaller dia piston.
vme250
Postby vme250 » Wed Jul 28, 2010 10:02 pm
OK if you need a new caliper this is it, it looks exactly like the grimeca except piston is 38mm instead of 41, so a seal kit for this won't work in the grimeca :(
Brembo, F08 caliper, left
[Part Number: 18652201]
Complete Brembo twin piston caliper. Fits front left when mounted in front of fork tube, fits front right when mounted behind fork tube. Fits rear when mounted below axle. Includes pads, anodized aluminum pistons and single large bleeder are installed. Most big twin models 1974 through 1997. 850T T3 Convert G5 1000SP, SP2, SP3, Cal2 Cal3 Cal1100, MilleGT, Strada, T4, T5, 850 LeMans, LeMansII, LeMansIII, CX100, probably more.
vme250
Postby comanche91 » Wed Jul 28, 2010 10:38 pm
This is good info - thanks. :-D Threads correct for use with the stock hose? I have mushy front brakes on my Silver Star; no leaks on the master cylinder or the caliper. Have tried every bleeding technique I know, and I've been bleeding brakes for years. The lever starts off firm and normal, but deteriorates after a mile or so and I have to double pump to stop. I have no loss of brake fluid. I'm pretty sure my problem is the master cylinder, and have one coming. But I'll keep this post in mind for the caliper.
-Don
1-3/4 1995 Silver Stars
comanche91
Return to 500 cc
Users browsing this forum: No registered users and 90 guests
