Rotax 500 Oil Leak
Rotax 500 Oil Leak
Postby nikitino » Sun Jun 07, 2009 7:00 pm
I finally tracked down a persistent oil leak on my Rotax 500 engine on my Saxon Country 500. It's coming from behind the chain sprocket on the engine. It's a pretty good leak and needs to be fixed. Do i maybe just need to tighten the sprocket nut? Is there any trick to this and does anyone know the torque spec for that nut? Or maybe do i need install a new seal behind the spocket where the shaft goes into the engine? Any suggestions appreciated...thanx
nikitino
Re: Rotax 500 Oil Leak
Postby DAVID THOMPSON » Mon Jun 08, 2009 8:45 pm
seal behind sprocket part number 230-395 atk or ron wood or a good bearing shop 25x40x7
part number and size same in atk book and mz book
:D
Postby nikitino » Tue Jun 09, 2009 11:08 am
Thanks, i ordered the seal from Ron Wood site.....hopefully i don't need a new bearing or anything. The guy at the shop says you can change the seal without draining the oil by laying the bike on its side....
nikitino
Return to 500 cc
Users browsing this forum: No registered users and 91 guests
