Grimeca Front Master Cylinder(rebuilding)
Postby jbthumper » Wed Sep 14, 2005 2:06 pm
Hi all,
Does anyone know any compatible rebuild kit that might fit the front master cylinder???or OEM ones???
also...how much do they cost??
Appreciate all the help...
:smt033
jbthumper
Postby jbthumper » Fri Sep 16, 2005 2:41 am
anyone?? :(
:smt033
jbthumper
Postby keithcross » Fri Sep 16, 2005 12:47 pm
Which model??
Postby jbthumper » Fri Sep 16, 2005 1:38 pm
hi,looking for the 125... i think the 125 have the same master pump as the 660baggy...
:smt033
jbthumper
Postby jbthumper » Thu Dec 01, 2005 11:23 am
anyone??
any compatible rebuild kit??or ANY rebuild kit for that matter....???
i only know grimeca off ducatis'...
FYI the 125 shares the same FF master cylinder as the baggy...
thanks. :-)
:smt033
jbthumper
Postby dpaarman » Thu Dec 01, 2005 1:03 pm
I'm checking on the OEM Gasket kit for your 125, it contains 7 pieces. I'll update as soon as I get any info :!:
MidAmerica PowerSports Plus
Don;
816-777-1785
dpaarman
Postby jbthumper » Thu Dec 01, 2005 1:24 pm
thanks!if u can't find it, maybe i'll try the front brake pump rebuild kit of an aprilia make or something... :-)
:smt033
jbthumper
Postby phlat65 » Thu Dec 01, 2005 8:17 pm
the front pads are the same as the aprillia Pegaso, so I would guess the master is the same. also, the KTM dual sport bikes upto 2000 or so use the same front controls, the brake light switch is the same for sure, maybe they also use the Grimeca master...
2001 MZ Black Panther
phlat65
Postby old paul » Thu Dec 01, 2005 10:47 pm
Worst case scenario, if you cannot find anything, take the o rings and seals to any good parts store. They'll have something the same size.
Motorcycling used to be my second favorite thing, but now that I've become an old man, it's moved up a notch.
old paul
Postby jbthumper » Thu Dec 01, 2005 11:42 pm
phlat65,
the 125 only share the same m/c as the baggy...calipers off the 125 are japanese(weird,huh? :lol: ) but will still keep a look-out for those ktm m/c.
old paul,
thanks.
:smt033
jbthumper
Postby Hoke » Fri Dec 02, 2005 12:27 am
Tip: The Baggy front brake looks exactly the same as the Yamaha TTR 600 Brembo front brake ;-)
Hoke
Postby jbthumper » Fri Dec 02, 2005 2:25 am
hey thanks! this is getting better and better!! :-D :lol:
:smt033
jbthumper
RT 125 Master Cylinder Rebuild Kit
Postby dpaarman » Fri Dec 16, 2005 11:13 am
OEM Rebuild kit #8050751000; Retail = $ 15.88, In-Stock at MZ warehouse! Call with your contact info & I can get the kit drop-shipped to you! S&H should be around $8.00!
Don
816-777-1785
dpaarman
Postby jbthumper » Fri Dec 16, 2005 11:38 am
hi,
is that the part number from MZ??
if it is, i'll see if i can get it from MZ warehouse here(malaysia)...
might save me the s/h costs :-D
(i know....i know...cheapskate :lol: )
thank you! :-)
:smt033
jbthumper
Users browsing this forum: Google [Bot] and 12 guests
