Directionals, LED
Directionals, LED
Postby MichaelTorre » Wed May 09, 2018 5:15 pm
I am looking for a relay that will run 6 volt LED directionals. I have a double Fistful of electronic relays that will work on 6 volt lamp, but none of them work on a relatively insignificant load such as the LED directional bulbs draw.
Have any of you all run across a directional relay which touted self as a no load relay?
I can put a little one tenth of watt P lamp in the circuit and the directionals work fine but that defeats the purpose that I am trying to attain and that is a simple LED circuit that draws and insignificant amount of power. Can you help?
Thank you
Michael
MichaelTorre
Re: Directionals, LED
Postby MichaelTorre » Mon Jul 30, 2018 5:53 pm
https://m.ebay.de/itm/LED-Blinkgeber-la ... 3250648641
I bought it.
the gentleman was a prince to deal with.
shipping was very cheap and most importantly it works hundred percent LEDs .
no stupid resistors
m.
MichaelTorre
