Head Bolt Torque
Head Bolt Torque
Postby cameronda » Fri Sep 08, 2017 4:53 am
G'day there
What is the correct head bolt torque for a ES250/2
The book says 5 KG-M which I work out to be about 36 F-lb
Working on this I snapped a head stud
Some of my other bikes come in at 16-17 f-lb
Though my waterbottle is 29 f-lb
This has probably been asked before or sorted out, I can't find it
Thanks in advance, only taken two years to get back to the bike
Dave
cameronda
Re: Head Bolt Torque
Postby breakwellmz » Fri Sep 08, 2017 7:04 am
Postby MZCountryRider » Fri Sep 08, 2017 8:24 am
Something is wrong with that converter. 5 kg/m = 36 ft. lbs.
https://www.convertunits.com/from/kg+m/to/lb+ft
Charlie
'69 Guzzi Ambassador
'71 Guzzi Ambassador
'72 Benelli 175 Enduro
'73 Guzzi Eldorado
'76 Guzzi I-Convert
'77 Morini 3 1/2 Strada
'81 Ducati 500SL Pantah
'82 Moto Guzzi V50 III
'97 MuZ Skorpion Tour
MZCountryRider
Postby dandywarhol » Fri Sep 08, 2017 11:31 am
Was the bolt wet or dry?
Whale oil beef hooked
dandywarhol
Postby cameronda » Fri Sep 08, 2017 2:33 pm
If I recall I think dry, sometimes I put a bit of oil
Can not recall
two years to the day
cameronda
Postby cameronda » Fri Sep 08, 2017 3:12 pm
Can not recall
cameronda
Postby dandywarhol » Fri Sep 08, 2017 4:54 pm
There can be quite a difference between them both. Oily nut and bolt faces will take higher torque before the wrench clicks leading to the bolt stretching and potentially shearing
dandywarhol
Postby cameronda » Fri Sep 08, 2017 5:13 pm
I know three of the four tightened, and the other snapped
I was wondering if this is the correct torque or I worked it out wrong or just shit happens
Dave
cameronda
Postby breakwellmz » Sat Sep 09, 2017 1:20 am
MZCountryRider wrote:Something is wrong with that converter. 5 kg/m = 36 ft. lbs.
That is really bad!
I came across that one by chance and just assumed it would be right without even thinking about it. :oops:
