No spark in neutral ts250/1
Postby Robtom » Tue Dec 27, 2016 12:17 pm
Hi,1st posting so be gentle with me.
I am in the process of total rebuild of a 1979 ts 250/1.Just wired up and everything OK but can only get spark in gear,in switch positions 2345.Neutral switch appears to be ok(neutral light goes out when in gear & on in neutral).Any ideas gratefully accepted.
Also how does the throttle prevent starting if open during kicking over?.
Robtom
Re: No spark in neutral ts250/1
Postby Robtom » Thu Dec 29, 2016 12:35 pm
Problem sorted.wrong connector block used.started first kick after 3 years.
Robtom
Postby DAVID THOMPSON » Thu Dec 29, 2016 3:03 pm
IF the slide is up.. the vacuum the engine draws on the carb does not happen so very little fuel is drawn
into the motor
Users browsing this forum: No registered users and 135 guests
