Are Grimeca caliper seals tapered ?
Postby keleto » Tue Nov 22, 2016 10:49 am
Hi, Are Grimeca caliper seals tapered or square section ? Thanks (Edit forgot to mention the bike is an ETZ251 with the later, caliper made by Grimeca)
keleto
Re: Are Grimeca caliper seals tapered ?
Postby Eric Frith » Thu Nov 24, 2016 10:30 am
I'm fairly certain that the seal is a square section, some calipers do have a tapered seat that gives the effect of a tapered seal.
Eric Frith
Postby keleto » Fri Nov 25, 2016 2:40 pm
Many thanks. The old seals I removed DID appear tapered but I could not detect any significant taper on the new ones, so I think you might be right that the taper comes from the caliper groove itself. The new seals seem to work OK so that is the main thing.
keleto
Users browsing this forum: No registered users and 218 guests
