Rough running in the powerband, knocking/pinking ? (ETZ251)
Postby keleto » Sat Sep 10, 2016 5:20 am
Between about 4800 and 5400 revs my engine seems to be knocking/pinking, or perhaps it is exhaust crackle ? It smooths out afterwards and more throttle seems to help which seems to kind of suggest a touch of lean mixture, but I already have quite rich settings and cannot really go much richer without plug fouling.
I have retarded the ignition to 2.0mm BTDC and started using premium (high octane) fuel which had made it a LOT better, but it is still noticeable. My carb needle is in the 4th position (ie one step richer than stoichiometric) and I have used a 140 main jet instead of 130. My plug colour is just on the rich side of perfect as one would expect with this arrangement. I have a morris minor air filter which is believed to be a little easier breathing than the stock one, and an aftermarket exhaust silencer (not a racing exhaust, just a generic china replacement). My squish measurement is good (1.1mm) and I am using a B7HS plug.
Any suggestions ?
keleto
Re: Rough running in the powerband, knocking/pinking ? (ETZ2
Postby DAVID THOMPSON » Sat Sep 10, 2016 2:39 pm
try a plug of a different brand same heat
and about a week after you get a 2 smoker running perfect expect a hole in the piston top :smt040
Postby keleto » Mon Sep 12, 2016 9:26 am
Yeah, easy to get them to run, but hard to get them to run really well. I have changed to a slightly colder plug for the moment as one was available, when the weather is nice I will try it out. Regarding a different plug brand, what brand would you recommend ?
keleto
Postby DAVID THOMPSON » Mon Sep 12, 2016 10:27 am
I use Bosch a lot
in the day when i had 2 smokers i used lodge and klg but i think they are not made any more at least i can not find them
my old Yamaha ym1 305 cc use the same Bosch plug as my later R50s BMW 4 stroke and was not bad about fouling them
Postby AIRMANBEAR » Fri Oct 11, 2019 9:50 pm
keleto wrote:Between about 4800 and 5400 revs my engine seems to be knocking/pinking, or perhaps it is exhaust crackle ? It smooths out afterwards and more throttle seems to help which seems to kind of suggest a touch of lean mixture, but I already have quite rich settings and cannot really go much richer without plug fouling.
Any suggestions ?
YOU HAVE TRIED WHAT I HAVE TRIED AS WELL. TO NO AVILA...THE GERMANS HAVE TOLD ME TO INCREASE THE CHOKE A BIT TO STOP THE PINGING (USA TERM).. BUT I DONT LIKE DOING THAT ….. I HAD SIMILAR PROBLEMS WITH MY 350 JAWA AND A U.S,A. 2 STROKE RACE MECHANIC TOLD ME TO DRILL A 1/8 HOLE IN THE PISTON JUST BELOW THE LOWER RING NEAR THE EXHAUST PORT ….. THIS COOLS THE WALL NEAR THE EXHAUST PORT WITH THE FUEL/ OIL MIX WHICH OVERHEATS AND CAUSES PINKING AND SEIZURE ..
EVER SINCE I DID IT NO MORE PROBLEMS,,,,,,,,,,,,,,,,...………… ED in N.Y.
AIRMANBEAR
Postby Puffs » Sat Oct 12, 2019 4:47 am
Not sure if the OP is still with us, but:
- the non-standard exhaust might give too much back pressure; that might contribute to the problem & cause the engine to run hotter;
- try an NGK 8, is what I used for a long time;
- ignition: best stick to the standard 2.5-3.0mm bTDC (late may also cause the engine to run hotter);
- if more throttle seems to help, that suggests it's not knocking/pinking/detonation, as in that rev range more throttle increases the degree of filling of the barrel, so increases compression pressure. Nevertheless, you could try a slightly thicker head gasket to reduce the compression pressure.
- Are you sure your mixture is not too rich? Surely a lower resistance filter might need a bigger main jet, but 140 is quite a bit over the standard 130. Stoichiometry is the calculation of reactants and products in chemical reactions - had to look that up.
- Yes, I've heard of drilling of holes in the piston to enhance lubrication - in race bikes. Not sure a standard ETZ needs it. But it raises the question: is your lubrication sufficient? In my 251 I had my doubts, and converted it to premix.
Postby Puffs » Thu Oct 17, 2019 10:49 am
I have been doing a bit more reading on knocking/pinking/detonation, and a particularly interesting article is https://www.millennium-tech.net/detonation.php. Prime learning from that is to detect detonation by:
1) Look closely at the plug. Detonation (even slight) will show up as tiny speckles on the spark plug insulator. It appears like tiny metallic balls when magnified.
2) Take off the head & look for pitting in the squish band area, on piston & head.
I also remembered the point of those small holes in the piston at the exhaust side, which the article also shows.
Those are for lubricating an exhaust bridge, which some bikes have, but the ETZ does not. Drilling a 1/8" hole below the rings might actually upset the breathing, as you create a pathway from the crank case directly to the exhaust.
Postby Blurredman » Fri Oct 18, 2019 2:35 am
I imagine on a Rotary or Reed valve induction engine, it would be okay to have the hole there.. ?
Postby Puffs » Fri Oct 18, 2019 4:36 am
It's the exhaust port that's shown there, not the intake port. More: http://blog.wiseco.com/two-stroke-how-t ... tion-holes.
Without an exhaust bridge, such a hole will make a connection between the crankcase, so the volume below the piston, and the exhaust. That connection will open when the piston moves upwards, typically when the top of the piston gets near the top of the exhaust port. The intake will then also be open, and the piston sucks mixture through that, and then also a bit through that hole from the exhaust. It's a sort of EGR, only not as you know it. And on the way down the piston will push some mixture straight into the exhaust.
I'm not saying the engine won't run, and I do not know what the effect will be. Never tried it, and I am surely not going to try it either, because it does not seem appealing to me. And the ETZ does not have an exhaust bridge that needs lubricating.
These exhaust bridges have been in vogue a while in MX race bikes, the idea being that you can have a bigger port size as the ring gets supported in the middle. But the problem with them is that they are rather thin pieces of metal that are exposed to the exhaust gasses at their hottest. Poor thermal connectivity to the rest of the barrel means that bridge gets very hot, hence expands. Nice idea, but it can causes seizures; don't know if they are still common.
